93 acura integra blower resistor
Old Jan 1, 2008 | 04:19 PM
invasian_boy's Avatar
Default 93 acura integra blower resistor
i was wondering if anyone can tell me to locate the blower resistor in my car? or any isntallation knowledge suggestions would be great thanks alot.... is it hard to replace the resistor?
Modified by invasian_boy at 12:39 PM 1/3/2008
Old Jan 3, 2008 | 11:39 AM
Default Re: 93 acura integra blower resistor (invasian_boy)
*Bump*
please help i really need help thanks
Old Jan 3, 2008 | 11:47 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Should be very easy to reach if you remove your lower glove box. There should be a wire harness going to a 4-prong plug either on the lower part of the round blower housing assembly, or possibly in the air duct just to the left of the blower housing (between the blower housing and heater core). It should be just 1 screw holding it in there.
Actually it's not on the bottom but near the bottom of the blower housing.
#7 in this pic, part number 79330-SK7-003, $23.48 from http://www.sonsacuraparts.com
Old Jan 4, 2008 | 03:27 PM
Default Re: (PatrickGSR94)
thanks alot for your post id check it out n see what happens thanks again
Old Jan 4, 2008 | 07:08 PM
db1_jdm's Avatar
Default Re: (invasian_boy)
i just recently replaced mine, simple only 2 screws hold it
Old Jan 4, 2008 | 10:19 PM
be18see1's Avatar
Default Re: (db1_jdm)
got a new one for $1.50 from pick n pull. now i get to have m2 and high PLUS m1 and low! i kind of took a chance that one i grabbed wasnt bad too though. get on http://www.g2ic.com, they also have a way that you can fix it yourself with resistors that you can find at radio shack for like 2 bucks.
Old Jan 5, 2008 | 03:57 AM
Mr. DB2's Avatar
Take out your glove box and it's right there.should only take you 15 min. tops.
Old Jan 5, 2008 | 01:26 PM
Default Re: (Mr. DB2)
yeap just like u guys said thanks alot
Old Jan 5, 2008 | 07:38 PM
Community Builder
Default Re: (be18see1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by be18see1 &raquo;</TD></TR><TR><TD CLASS="quote">got a new one for $1.50 from pick n pull. now i get to have m2 and high PLUS m1 and low! i kind of took a chance that one i grabbed wasnt bad too though. get on http://www.g2ic.com, they also have a way that you can fix it yourself with resistors that you can find at radio shack for like 2 bucks.</TD></TR></TABLE>
Had the same problem on my old 89 Camry, the lowest speed wouldn't work. It had the same style of blower resistor. I think I picked 2 or 3 different ones out of different junk yards and none of them were fully functional (very common problem on those cars). I ended up just buying some wire-wound resistors from Radio Shack and fixing it myself.
Interestingly the resistors I bought are no longer carried by Radio Shack.
jne
Feb 8, 2010 10:23 AM
mpf90
Mar 23, 2009 11:54 AM
Slow Ek
Sep 2, 2008 04:26 PM
cd5chicago
Jan 3, 2008 06:43 AM
rjardy
Jan 12, 2003 03:56 PM
