Headunit and Ipod/Zune options
Old Jan 1, 2008 | 04:08 PM
djs87's Avatar
Default Headunit and Ipod/Zune options
Ideally I would like to keep the stock head unit in the car and was wondering if theres a way to get an ipod hooked up to it. I know they have the cassette tape things that hook up to an aux input and into the cassette player that might work, but will I lose sound quality if I do that?
The other option I was considering is a new headunit, but since the radio is wider on top, and rounded off on the edges, im skeptical that they make mounting kits that will keep it looking as nice and flush. Anybody have pics of their setup or advice on this? Thanks in advance.
Modified by djs87 at 11:27 PM 1/1/2008
Old Jan 1, 2008 | 04:48 PM
lilbinky's Avatar
Default Re: Headunit and Ipod/Zune options (djs87)
Here are some pics of my Eclipse CD 3000 headunit installed using a Metra dash kit. I think it turned out pretty good and it is just as flush as the factory piece.
This is the best pics I have right now but if you would like more along with the part numbers you will need and install tips I wouldbe more than happy to help.
Also there may be a piece made by one of metra's other companies, called Axxess, that will help you retain the factory radio!
Here is the site!
http://www.axxessinterface.com/default.aspx
Old Jan 1, 2008 | 05:19 PM
Todd00's Avatar
I said I don't want a title!
Default Re: Headunit and Ipod/Zune options (lilbinky)
Looks good, but you can tell it is not OEM. If you have a Type-S, can't you buy the base RSX radio faceplate (since it is a single DIN) and work with that as a starting point?
FWIW, I tried a cassette adapter and you could hardly hear any sound through the OEM Bose radio. Not sure if I got a crappy adapter or not, but it was the best one I could find.
Old Jan 1, 2008 | 10:23 PM
djs87's Avatar
lilbinky thats almost perfect. HUGE help bro. Ill probably get that dash kit along with a head unit of my choice.
If You got part numbers and tips, Ill gladly hear them all. Thanks again
Old Jan 2, 2008 | 07:03 AM
lilbinky's Avatar
Default Re: (djs87)
Hey man here is the part numbers and links to their instructions! You can purchase these from your local Circuit City because I know for a fact that they carry Metra and their part numbers will be the same!
Dash Kit - MET 99-7867
http://documents.victorytechno...7.pdf
Wiring Harness - MET 70-1725
http://www.metraonline.com/products.aspx
Good luck with the install and don't forget the screws under the radio!
Old Jan 2, 2008 | 07:29 AM
MadDawg15's Avatar
go with the radio transmitted adapters, like an itrip. i have one and it works perfectly. just plugs into the cigarette lighter and pick a fuzzy station. and the sound is perfect.
Old Jan 2, 2008 | 07:59 AM
lilbinky's Avatar
Default Re: Headunit and Ipod/Zune options (MadDawg15)
The iTrip is a good choice but nothing can match true digital connection! Also the expandability that he will gain from an aftermarket headunit is awesome (i.e. sat radio, ipod connection, bluetooth handsfree calling, etc., etc...). He will also improve his sound quality with an aftermarket deck.
Old Jan 2, 2008 | 09:25 AM
djs87's Avatar
Ya I considered a transmitter but Id rather have a true connection. Itll be a week during the next heat wave that I do this anyway so I can do it myself. Living in Buffalo, god knows when thatll be.
redbalut
Northwest (Sales)
Nov 13, 2005 10:30 AM
allm0torGSR
11
Feb 10, 2005 07:07 PM
zumiez007
Audio / Security / Video
Jan 12, 2005 07:40 AM
RUBZERK
Sep 5, 2004 01:24 PM
