Ls vtec integral with type-r pistons???
Old Jan 1, 2008 | 02:33 PM
96integralsvtec's Avatar
Default Ls vtec integra with type-r pistons???
I have a ls vtec integra with gsr pistons and I was thinking about getting some usdm type-r or jdm type-r pistons and I was wondering if it will give me a lot more power or just a Lil more.and how much I will notice the gain.let me know
Old Jan 1, 2008 | 03:30 PM
northemt88's Avatar
Default Re: Ls vtec integra with type-r pistons??? (96integralsvtec)
This might help
http://www.c-speedracing.com/h...c.php
Old Jan 1, 2008 | 03:49 PM
Default Re: Ls vtec integra with type-r pistons??? (northemt88)
hey thanks for that site pretty sick
Old Jan 1, 2008 | 04:04 PM
northemt88's Avatar
thats what i'm here for
Old Jan 1, 2008 | 05:43 PM
Mfoehrkolb's Avatar
if you use the LS rods with the ITR pistons, your gonna need to have machine work done. Keep that in mind.
--- I would think it would increase horsepower but not too dramatically. Maybe a 20-25whp. Guesstimate, don't quote me on that though.
Old Jan 1, 2008 | 06:01 PM
weavertime1's Avatar
Default Re: (Mfoehrkolb)
It'll bump the compression as I am sure you have already found out...you will gain nothing without tuning, and even with a proper tune do not expect 20 - 25 whp. I am not bashing on you Mfoehrkolb, you did say it was a guesstimate!
Old Jan 1, 2008 | 06:37 PM
Mfoehrkolb's Avatar
ya, tuning is key on a good running car. jeff evans FTW! tbh, i wouldn't even use oem itr pistons. if your gonna and wanna do something all motor. get some nice after market ones.
Old Jan 1, 2008 | 09:20 PM
northemt88's Avatar
You cpuld alway just look around for high comp pr4 or p72 pistons then you can run them without any machining. Not 100% sure if you need to on the p73s.
Old Jan 1, 2008 | 11:42 PM
Default Re: (northemt88)
What would happen if I ran p73s with no machining?
Old Jan 2, 2008 | 03:31 AM
GSR-C5's Avatar
Default Re: (96integralsvtec)
the Rods won't fit into the piston, i had to mill off .45 off each side of the rod on mine.
Old Jan 2, 2008 | 02:48 PM
Default Re: (GSR-C5)
well could I run p30s with no milling?
Old Jan 2, 2008 | 05:04 PM
Mfoehrkolb's Avatar
you can use gsr, p30s, pr3's without no milling.
96integralsvtec
Jan 7, 2008 11:26 PM
92integra-R
Jan 17, 2007 01:52 PM
the.hamburglar
Dec 28, 2005 03:46 PM
spoonzdelsol
12
Aug 7, 2005 08:13 PM
chuckd05
Mar 26, 2003 08:15 AM
