Early Redline?
i got a 95 EX that for some reason havin the redline at 6200 instead of 7200..i gutted the cat to see if that was the problem..didnt help..set the dizzy to TDC..didnt help..im thinkin it could be fuel filter but not real sure..anyone have any other suggestions for me to look at/check out??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bpkmrtoes »</TD></TR><TR><TD CLASS="quote">might be a stupid question... but... do you have the right ecu?</TD></TR></TABLE>
I was thinking that might be a issue.
A non-vtec ecu would have a low redline like that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">
A non-vtec ecu would have a low redline like that.</TD></TR></TABLE>
sounds like a tach being off and someone took your p28 and gave you a p05 p06 or p07
what are more of the syptoms does it bogg like it wants to go more but cant? Or does it just bouce of the rev limiter? MY hatch with a b16 was doing that I troubleshooted it. And it turned out to be the ELD(electronic load dector) was bad and its located inside the fuse box on the passenger side right by the battery but you have to replace the whole fuse box. Gl with fixing it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redb16coupe »</TD></TR><TR><TD CLASS="quote">check you oil level and also check your vtec pressure switch sometimes if you dont have the right oil pressure it goes into protect mode my coupe was doing that </TD></TR></TABLE>
You mean limp mode?
If he was in limp mode he wouldn't be able to go near 6200
You mean limp mode?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gibsanez »</TD></TR><TR><TD CLASS="quote">
You mean limp mode?
If he was in limp mode he wouldn't be able to go near 6200</TD></TR></TABLE>
yeah he would my car is in limp mode atm cuz my tranny mount and the car rev limits at 6500~ on a stock p28 ecu
You mean limp mode?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aralliius »</TD></TR><TR><TD CLASS="quote">
yeah he would my car is in limp mode atm cuz my tranny mount and the car rev limits at 6500~ on a stock p28 ecu</TD></TR></TABLE>
The ****?
The ****?
What the %^$%&
What the %^$%&
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">What the %^$%&</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black_EM1 »</TD></TR><TR><TD CLASS="quote">The ****?</TD></TR></TABLE>
He's 16, an 07, and 34 of his 38 watched topics are in A/C. Pretty much self explanatory.
i put in a d15b for my friend in his 95 ex and his hits @6200 as well with a stock p28. My guess is the fuse that dude was talking about above me or possibly wrong or bad ecu.
My '94 Civic with a GS-R (on a chipped P28) did the same thing...originally I thought it was an issue between the ECU and the distributor...the car ran great, then just randomly started redlining at 7K instead of 8K...
...in the end, it was a bad gauge cluster...you might wanna see if you could swap with a friend or something and give that a shot.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1WickdTeg »</TD></TR><TR><TD CLASS="quote">like i said above...there is no CEL...this is about to get on my damn nerves..i hate issues like this...</TD></TR></TABLE>
Well one thing to fix the issue stop taking that poor motor to red line who cares what red line is why even hit it theres no power up that high
sounds like either a bad ecu, which is doubltful. or your tack is way off. id check your spark plugs and wires also. possibly theyre arching at a higher rpm and causing it to seem like the rev limiter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cln92eg »</TD></TR><TR><TD CLASS="quote">
Well one thing to fix the issue stop taking that poor motor to red line who cares what red line is why even hit it theres no power up that high </TD></TR></TABLE>
overopinionated and under informative.
well im not randomly takin my motor to redline..i just got the car bout 2weeks ago and when i test drove it..it would only goto 6200 and he said it was the CAT. which makes sense in some way...it sounds like its missin alil at idle..like its poppin and its idling low..around 200-300 range..what about the fuel filter could it be clogged maybe??
