Removed/Reinstalled Distributor from working car, now won't start
Old Jan 1, 2008 | 10:18 AM
rodvang's Avatar
Default Removed/Reinstalled Distributor from working car, now won't start
So my car isn't running right now and I have a friend who has the same engine as me. So we removed the distributor from his car to mine because I didn't have any spark. I got spark but my car was still not turning over so we go to put the distributor back into his car and now his car will not turn over either. Both our cars crank but does not turn over. Any ideas? The only thing we did was take the distributor out of his car and put it back in.
New Update also.
I installed the distributor back into my car cause I realized the plug order was wrong when I tried it on my car and it fired my car up. So I know the distributor is good..My friend's car was running when we took out the distributor from his car so I don't know what else it could be..
Update 1/2/08
So I reinstalled the distributor, checked compression (140, 130, 130, 130), reset ecu, checked spark and fuel..nothing seems to be out of the ordinary..what else is there to start a car? Anything else I need to check?
Modified by rodvang at 2:36 PM 1/2/2008
Old Jan 1, 2008 | 10:45 AM
God-Driven's Avatar
so none of the cars have spark now? what year integra?
Old Jan 1, 2008 | 10:47 AM
rodvang's Avatar
Default Re: (God-Driven)
95 integras. Both cars have spark, just not turning over. Wire order is correct.
Old Jan 1, 2008 | 11:08 AM
rodvang's Avatar
Default Re: (rodvang)
Why is it not running? Making me frustrated now. I don't see what could have happened in the hour that it was out.
Old Jan 1, 2008 | 12:44 PM
rodvang's Avatar
could something in my car have burned out something in the distributor before we put it back into his car?
Old Jan 1, 2008 | 01:46 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Make sure you didn't install the distributor 180 degrees out of time.
Old Jan 1, 2008 | 02:32 PM
rodvang's Avatar
Default Re: (PatrickGSR94)
if i did install it 180 degrees out of time, all i would have to do is turn the piece that goes into the cams 180 degrees right? Cause I tried that also.
New Update also.
Old Jan 1, 2008 | 02:36 PM
abraminho17's Avatar
it could be the rotor...
Old Jan 1, 2008 | 02:44 PM
rodvang's Avatar
Default Re: (abraminho17)
well from the update I posted, I don't think it is anything with the distributor. He has an alarm on his car but the alarm usually has a start kill where you can't even crank the car so I don't know what else it could be.
Old Jan 1, 2008 | 05:24 PM
rodvang's Avatar
bump...any ideas?
Old Jan 2, 2008 | 12:04 PM
rodvang's Avatar
bump for some help
Old Jan 2, 2008 | 01:50 PM
DOHCgarage919's Avatar
From: Why To Steal My Car, NC, United States Of America
you might of installed the distr. on wrong or 180 degrees off like post above, i did the same thing and reinstalled it and fired up, check it again
Old Jan 2, 2008 | 02:41 PM
rodvang's Avatar
Default Re: (DOHCgarage919)
what do you mean by installing it 180 degrees off? Just the piece going into the cams is 180 degrees off? Cause if that is what you are talking about, I have rotated that 180, 360, and every other degree also.
Old Jan 2, 2008 | 04:21 PM
lmike6453's Avatar
once when doing a compression test there was a weak battery and we had to jump it because of all the sparking you're giving it and no alternator working...try jumping the battery while you are starting it....otherwise, open distributor...take off cap n rotor...then test to ohms of the 2 terminals in the top right part of the distributor w/ the positive and negative wire disconnected...they should be between .6-.8 ohms...let me know if you need detailed help
Old Jan 2, 2008 | 05:04 PM
rodvang's Avatar
Default Re: (lmike6453)
i'll have to try that tomorrow..anyone got anything else to check?
Old Jan 2, 2008 | 09:09 PM
dturbo's Avatar
are you getting a good spark? had a friend who had a weak battery and didnt get a strong spark.
Old Jan 8, 2008 | 02:24 PM
rodvang's Avatar
Default Re: Removed/Reinstalled Distributor from working car, now won't start (rodvang)
RAWR! So I recieved my new distributor today and I got the wrong one...so I have to wait another week for a new one. I think the timing may have jumped because when cylinder 1 is up the rotor is not facing the #1 spark plug. It is towards the #2. Cam gears are also not lined up. Do these symptoms fit a timing issue problem?
Old Jan 9, 2008 | 05:45 AM
lmike6453's Avatar
yes, unfortunately
ratchetEDsedan
14
May 30, 2017 07:08 PM
warfield21
Apr 15, 2017 12:26 PM
EG_SINZ
Aug 13, 2013 03:37 PM
Jhicks
Jan 28, 2012 07:08 PM
ejprimo
Apr 25, 2003 10:20 AM
