D4 blinking and car keeps turning off
my car didnt have any power, no crank at all, after messing with the battery terminals the car turned on but the d4 light was blinking and the car wouldnt go foward, i had to almost floor it, for it to go, when i got home i turned it off and started it up again and it worked good, i need motor mounts, wen i shift the car jerks and the motor moves, can that be the problem? is this a bad tranny? or is it something simple? thanks
D4 blinking indicates a problem with the TCU. You should replace the motor mounts, but I doubt they cause the blinking. Is the problem consistent, or have you only had it once?
yeah, im going to get it checked today, the problem just came up yesterday, earlier i turned it on and nothing happen started up fine, i am low on tranny fluid, do you guys think that could cause the problem? or is it somehting eletrical, like sensors?
i have a 94 lx! yes just one time ok today i did the the tcu test, and i didnt get any blink, i also did the ecu and i got 7 flashes which is throttle sensor, do you guys think thats was causing my surging idle?
See if you can swap the TPS with a friend or something and see if it solves the problem. EGR ports might also be clogged too, adding to the problem
T_bones
Sep 5, 2005 03:11 PM
