What's This?
http://www.hondamotorsonline.com/sho...20Long%20Block
b20 long block? what else would i need to get this motor going in a 1994 hatch?
and that? so all i would need would be ecu, tranny, and axles? would it be easier just to be the full swap?
The b20 comes out of the CRV it is 2.0 liter non vtec motor. It is a really nice engine but obviously if you don't know what this engine is, i suggest you not tackle it. To get the swap working you will need Ls intake manifold, TB, tranny, axles, wiring harness, ecu, sensors, mounts, header, intake, etc. There is more but you get the idea. Easiest way to do the swap is buy an LS full swap then buy the B20 longblock swap over everything you need, then sell the LS longblock. You can also try to add vtec on this engine commonly referred to as CRVtec
i heard steve(honda motors online) sells that swap with the intake manifold and TB already installed so all you would really need is wiring harness (stock could work) LS ecu, tranny and axles.
[Modified by KAMiN, 1:19 AM 6/29/2002]
Complete motor,intake and exhaust manifold,injectors,fuel rail,throttle body,distributor.Long blocks have under 18,000 miles and come with 100% start up warranty. Motors come with no sensors broken guarantee.
$799+shipping? not bad eh?
EG-SIXV-TEC
Feb 20, 2009 07:35 PM
