Passenger side window problem...help plz
Old Dec 31, 2007 | 10:01 PM
Tru2Less's Avatar
Default Passenger side window problem...help plz
well my window is all messed up....lets just say it goes down but it won't got back up so i took it to the garage thought it was the motor that was wrong but it wasnt....so they checked it by bringing out the battery and testing out the motor it was fine they said that the problem is the wiring well they said there is a bad wire under the dash so to do this job it would cost around 300.....thats crazy just to fix the wire.....i was just wondering if their is any cheaper way to fix this if so then what or i can look for the bad wire myself if so then what do i do and what do i need....thanks
Old Dec 31, 2007 | 10:14 PM
meyerman_b16a2's Avatar
Default Re: Passenger side window problem...help plz (Tru2Less)
hey first off.. its funny, cuz i just read one of your posts about what car to get, i see you went with the civic... could to hear. secondly... it sounds kind of odd.. the wiring concept? my driver side window does it all the time, where i can roll it down, but not up.. all i do is take the door panel off, and make someone hold my window when i unscrew the 2 screws to completely detach the window, and then put it back on track.. make sure its actually on track, cuz if its not.. thats what you gotta do.. thats why i want my em1 to just have manual windows sometimes. if it is on track.. i guess i'd have to actually see it to tell you my thoughts.. 300 bucks or whatever.. i'd go to a different shop.. check around.. good luck man!
Old Dec 31, 2007 | 10:15 PM
p.s... i hope that was you anyways.. asking if you should do integra or civic.. if not.. nevermind that. haha
Old Jan 1, 2008 | 05:35 AM
Tru2Less's Avatar
well appreciate it....i think its on track cause when it goes down no problem it don't move anywhere....and then when they brought it back up it didn't fly around so its definitly the wiring i was just wondering if i can make new wires there but i will have to know like what is it.....like is it just neg and pos and things of that type
Old Jan 1, 2008 | 07:11 AM
NOFX's Avatar
H-T White Ops
Does it even try to go back up? Does it make a sound? Anything?
Old Jan 1, 2008 | 07:21 AM
a_joshchang_story's Avatar
possibly something is bent? my ish was bent.. went down fine.. when it wouldnt go up... i forced it and it all shattered. took it apart. was bent.
Old Jan 1, 2008 | 08:58 AM
Tru2Less's Avatar
nope don't make no sound...i need to fix this up cause the wheather condition is crappy here...so lets just say it don't go back up and make a sound and im not really sure about anything being bent it was tested and was said that "WIRES ARE MESSED UP" so i dont know what to do.............is there any way to do something ghetto like connect it to the battery so it will go up and down?
Old Jan 1, 2008 | 04:03 PM
NOFX's Avatar
H-T White Ops
So you don't even hear the motor running at all then?
You could probably tear the panel off and bring it up manually, but it's a pain in the ***.
Old Jan 1, 2008 | 04:30 PM
actek23's Avatar
Default Re: (NOFX)
its happened to alot of civics on honda-tech
but i dont think its a wire issue.
look at the rubber track (by the tweeter and the part by back of the door frame) in the window frame... look either inside or outside of the window and look at the rubber that its suppose to "glide" in between... sometimes that rubber gets crossed and stops the window from going up.
this is what i noticed with my drivers side window... only way for me to fix is is to pull the window towards the inside of the car while its going up so the rubber tracking doesnt
get in its path while its going up.
Old Jan 1, 2008 | 05:21 PM
jasoncrashtech's Avatar
Default Re: (actek23)
1- if it's starts and stops, then it's an open and closed circuit. follow the wires and find it with a test light. use your fuse panel above the kick panel driver's side. try fixing the wire or replace it.
2- if it doesn't work at all check the fuse.
3- if it tips and falls off track, check your window regulator.
hope it helps
Old Jan 1, 2008 | 06:38 PM
Tru2Less's Avatar
well ill check it tomarrow its like 10.36 p.m but thanks for the input well i might just put a new wire through it but if i do wouldnt i need to make the wire new from the driver side to the passenger side? well it don't start and stop but lets just say there is a UP switch and Down switch they both have neg and pos so the down works fine........but when trying to move up it doesn't work well it has been tested and its said to work but ill check thanks
portugueboy10
May 17, 2016 08:23 PM
GsRrrr
Jun 14, 2011 04:02 PM
da_33
Oct 10, 2007 08:23 AM
LB CRX
Jan 15, 2003 03:56 PM
Mycroft Holmes
Mar 14, 2002 07:42 PM
