CAR RAN PERFECT... THAN 20 MIN LATER IT WILL CRANK BUT NOT START
Old Dec 31, 2007 | 08:34 PM
blaxican05's Avatar
Default CAR RAN PERFECT... THAN 20 MIN LATER IT WILL CRANK BUT NOT START
Hey whats up im driving a 1995 Integra LS (Stock) So i have been driving around perfectly fine for the entire time ive owned the car and today was no dif.
i drove to a restraunt then back home and chilled for about 20 minutes before i had to go to work..... then i got in my car to leave and it cranks but will not turn over....
I have a kill switch so my immediate thought is ok i had the car off but that was not the case..... i checked all fuses under hood and the starter ignition under the dash. the fuel pump does not prime.
the battery is not dead and i have had my starter checked and its good to go....
HELP lol happy new year to me
Old Jan 1, 2008 | 04:22 AM
speedworksengineering's Avatar
Default Re: CAR RAN PERFECT... THAN 20 MIN LATER IT WILL CRANK BUT NOT START (blaxican05)
maybe your main relay is bad
Old Jan 1, 2008 | 08:51 AM
blaxican05's Avatar
Default Re: CAR RAN PERFECT... THAN 20 MIN LATER IT WILL CRANK BUT NOT START (speedworksengineering)
its not the main relay just checked.... Anything Else?
Old Jan 2, 2008 | 01:54 AM
welfarepc's Avatar
are you getting spark? (pulled a plug wire and checked to see if it jumped a spark to a ground?)
if you dont got spark i bet your ignitor bit it in your dizzy
99Ek_Fred
Jul 26, 2018 11:53 PM
mynameizstitch
26
Aug 5, 2012 04:33 PM
Dark19Acura
Apr 24, 2010 04:47 PM
szczerbanator
Jun 26, 2009 09:07 AM
fwdftw
52
Sep 5, 2006 11:31 PM
