valve cover how too..
Old Dec 31, 2007 | 08:26 PM
jasoncrashtech's Avatar
Default valve cover how too..
alright, so i misplaced the early ongoing picture's with paint stripping and prep.
sorry i'll haft to explain. i didn't use aircraft remover ( but there is nothing wrong with using it ) i used a spray on brand that i got from a kc paint supply store. i had to apply it about three times and it goes as follows
-spray the face of the valve cover for your first coat
-make sure you have water in a bucket near by in case it gets on your skin, paint stripper neutralizes with water and DO NOT GET IT IN YOUR EYES OR NEAR YOUR EYES !
-the first coat will start to bubble after a minute of so, after ten min. you might as well neutralize with water and clean with some old paint brushes you don't care about or a thick and fine bristled brush that won't scare the metal.
-repeat this process try to get all nooks and cranny's stripped of old paint. i also used compressed air after the paint stripper was neut. to get in some area's.
finally after i repeated this three times the paint was off. i then prepped with my mini pistol grip DA ( dual action sander ) but in you don't have one, sanding with 120, 150, will do fine. a wet scotch bright and compressed air followed.
and now prime ( i used ppg k36 primer surfacer ) 2 coats.
the mixture is 4:1:1 , k36, i can't remember the catalyst a ppg store should be able to tell you, and dt solvent 885 ( depending on room temp, it was around 70 degrees when i shot the paint. )
and boom it's boring grey !
at my shop we had a brand new element come in for a front end hit, the color was kiwi pearl. it looked sweet so i went with that color. i wet sanded with 320, then 400 in all area's i could reach and again i used a wet scotch bright.
the paint came out good, i was loving the color ! now for the letters
-get some tape, and a piece of a paint stick with some sticky 120 grit paper and sand.
note : i went sideways because i wanted to leave the sandscratches on the metal to leave a machined look.
now for the H, on the jdm cover.
it's important to be careful and patient, you could scratch your new paint job.
and there it is !
and it's ready. this isn't a high heat paint but it's more of show purpose. however i have two other covers i did the same way and they are holding up just fine.
Last edited by jasoncrashtech; Jul 2, 2013 at 07:27 PM. Reason: crappy spelling (blah)
Old Jan 1, 2008 | 12:26 AM
kelviiv's Avatar
Good Write up
Old Jan 1, 2008 | 11:23 AM
Acidcrakker's Avatar
Default Re: (kelviiv)
Wow those came out real nice.
Does anyone know where I can get paint to come out like that, but not with a spray gun. Like a rattle can.
Old Jan 1, 2008 | 12:04 PM
Default Re: (Acidcrakker)
what up acid ! howz the h22 going !
and to answer your question, just call up a local bodyshot around where you live and ask where they get there supplies. get an address and phone number. if you buy from them ask for " p pages" this will tell you all the info about the product you need. you will need catalyst, reducer ( or solvent ), and primer surfacer.
pm me if you have anymore questions !
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kelviiv &raquo;</TD></TR><TR><TD CLASS="quote">Good Write up</TD></TR></TABLE>
thanks
Old Jan 1, 2008 | 12:42 PM
Default Re: (jasoncrashtech)
Whaha. Thanks Jason that sparkle paint is great looking.
As for my H22. Its running so much better, than originally. I just got my Vtak cracking and its great. Whoa who.
Now all thats left is a Tuning system, and a tranny swap, then its off to body work and what not.
Old Jan 2, 2008 | 01:15 PM
Eibach95Civic's Avatar
Community Builder
damn. very impressive
Old Jan 2, 2008 | 03:28 PM
downsincedayone's Avatar
Default Re: valve cover how too.. (jasoncrashtech)
keep up thegood work
Old Jan 2, 2008 | 05:50 PM
Default Re: valve cover how too.. (downsincedayone)
thanks guys.
i've rattle canned valve covers like this and it still came out clean. good prep makes a big difference but the gloss doesn't last
Old Jan 4, 2008 | 07:22 PM
JRZ88DX's Avatar
that green is sick!
do my valve cover!!!
Old Jan 5, 2008 | 05:47 PM
vsmhatched's Avatar
awesome color
Old Jan 5, 2008 | 10:45 PM
JdmShwiggEG's Avatar
Old Jan 6, 2008 | 09:55 PM
boostedjdmdc2's Avatar
niiiiice!
Old Jan 7, 2008 | 12:27 PM
White Smoke's Avatar
i my honda
Global Mod
That turned out great! Nice write up
Old Jan 8, 2008 | 11:02 AM
inspector01's Avatar
Looks great. I don't assume that you clearcoated it did you??
Old Jan 9, 2008 | 05:43 PM
Default Re: (inspector01)
yes, base coat , clear.
ppg
Modified by jasoncrashtech at 9:57 PM 1/14/2008
Old Jan 9, 2008 | 06:11 PM
I thought it looked clear for sure, but my friend was told not to use clear when doing his engine bay cuz of heat, so i thought definately not on valve cover. I would love to see how it holds up cuz i want to do mine like that but i don't know if it will last.
Old Jan 10, 2008 | 10:31 PM
capster15's Avatar
Thanks for the info will come in handy
Old Jan 11, 2008 | 12:40 PM
k20utah's Avatar
great job on the write up
Old Jan 14, 2008 | 09:01 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspector01 &raquo;</TD></TR><TR><TD CLASS="quote">I thought it looked clear for sure, but my friend was told not to use clear when doing his engine bay cuz of heat, so i thought definately not on valve cover. I would love to see how it holds up cuz i want to do mine like that but i don't know if it will last.</TD></TR></TABLE>
for the most part, engine bays are always in single stage. the heat will be hard on the clear, and my motor is boosted. i will keep posting on how it is holding up
Old Jan 15, 2008 | 06:47 AM
-NA-aLL-thE-wAy-'s Avatar
EFSS153
Nice work. That's a great color, too.
Old Jan 15, 2008 | 07:16 AM
I'mStock's Avatar
Looks sick man, loving the attention to detail with the sanding marks!
Old Jan 15, 2008 | 11:19 PM
alltech.magoo's Avatar
Default Re: (I'mStock)
nice work
Old Jan 16, 2008 | 07:24 AM
Genuine Rolla's Avatar
wow....that color looks great...!
Old Jan 16, 2008 | 07:39 PM
SneezinCD5's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jasoncrashtech &raquo;</TD></TR><TR><TD CLASS="quote">yes, base coat , clear.
ppg
Modified by jasoncrashtech at 9:57 PM 1/14/2008</TD></TR></TABLE>
I can spot PPG from a mile away. Nothing can beat the shine of PPG.
