Hondata and wideband
Old Dec 31, 2007 | 04:17 PM
0TT's Avatar
0TT
Default Hondata and wideband
Ok I have a couple of questions for you guys;
Ive modified my OBD2a->OBD1 adaptor harness with bullet-connectors for inputs/outputs on the ECU side.
Im going to be using the PLX's white wide-band signal wire to the ECU D10-ELD.
There is a note in the help file saying that somtimes certain ELD resisters must be removed before this pinout can be used. I bought my P28 ecu directly through hondata and it was prepared for boost control by hondata.
....WILL I NEED TO REMOVE ANY RESISTORS??
Also I want to use B5-ACS switch input to switch between high and low boost... Do I need to manually rewire the switch by removing all the heater controls and opening it up OR CAN I... use the 'INVERT-INPUT' option to make the factory wiring function without modification to the switch's wiring?
I extended both the grey narrowband signal wire to the engine harness clips white O2 signal wire whilst also making an adapter with a 1watt 1k resister between the two black O2 heater wires. I also extended the white wideband wignal to D10-ELD. I perfectly soldered and heatshrunk the joints but would like to know... will this affect accuracy after voltage correction in hondata
PLX Devices reccomends connecting the M300 to the ECUs power and ground whilst also using two noise filtering capaciters.
I intend to used switched +12v from the under dash ingnition feed with a local ground. a). Do I need to use power at or near the ecu or can Hondatas vltage correction chart be used to correct any innacuracy? b). Does hondata advise the fitting of these capacitors??
Cheers
0TT
Jan 1, 2008 02:21 PM
duceduce22
Mar 24, 2006 03:46 PM
