Axles remove
Old Dec 31, 2007 | 01:19 PM
johnDX's Avatar
Default Axles remove
is there any other way removing the axles, insted braking off the lug nut on the axle
Old Dec 31, 2007 | 04:44 PM
Trakhor's Avatar
Torque Junkie
Default Re: Axles remove (johnDX)
There is but it's less practical. What are you trying to acomplish?
Old Dec 31, 2007 | 05:33 PM
Hanmin's Avatar
It's not that hard to take off the lug nut.
Old Dec 31, 2007 | 05:47 PM
EFsideways's Avatar
Default Re: (Hanmin)
If all you want to do is remove them from the tranny and not the spindle.Just remove the lower ball joint and shock fork bolt.Turn your steering wheel all the way to the side you want to remove and then get out an turn your rotor by hand further to remove from tranny.It will just pop out of the tranny,or use a flat head to pry gently.
Old Jan 2, 2008 | 09:21 AM
johnDX's Avatar
aight guys thanx for the help! i got them off already...
Old Jan 2, 2008 | 11:49 AM
alscrx's Avatar
Default Re: (johnDX)
As long as you got them off.....but unless you break that axle nut loose or remove the whole spindle.....there is no other way!
jmanuel
Aug 9, 2014 11:35 PM
sony224422
Jul 7, 2007 03:29 PM
gursh d
Dec 27, 2006 07:15 AM
projsectEF
May 22, 2006 08:36 PM
Exempt
May 21, 2005 09:46 PM
