swap ASAP help Flywheel & Clutch & press plate
hi there im going to be doing a auto conversion on my 91 civic dx 4dr i got everytying but i need to know what flywheel will i need to get it working will a si Flywheel & Clutch & press plate work off a 89 civic in my 91 ???
also i was wondering can i still use the same Flywheel & Clutch & press plate if i do a d16y7 swap and use the si tranny i got what Flywheel & Clutch & press plate & axels will i need to use thanks
Use the clutch and flywheel specific to your TRANSMISSION.
ie: d16y8 with 90 si trans, use the flywheel and clutch for the 90 si trans.
be advised: 88 models have a different spline count. You may need to research a bit more if you plan on using an 88 trans for any possible mating issues. If you have no plans to use an 88 trans, disregard.
https://honda-tech.com/zerothread?id=1551508
we have something called crx/civic FAQ read it learn from it!!!
justin-95si
Dec 10, 2012 12:08 AM
Canadian_EF
17
Mar 24, 2011 11:39 PM
ParistsCP
Oct 7, 2008 06:59 AM
DA91TEGGY
Jul 22, 2005 01:19 PM
