OEM or Mugen RTA bushings?
Old Dec 31, 2007 | 06:57 AM
wickedEFguy's Avatar
Default OEM or Mugen RTA bushings?
So I decided to go with another set of the RTA bushing on my 90 CRX since mine were worn out and cracked. From what I'm reading/hearing from several people is that with the energy suspension replacements you can't adjust toe in the rear and they'll to bind since it doesn't allow the arm to move freely.
My question is are the Mugen RTA bushing worth buying or should I just stick with a new OEM replacements? The spherical are out of my price range.
If I do end up buying th Mugen/OEM replacements does the metal sleeve have to be knocked out as well?
Lastly, where would I buy the mugen replacements?
Thanx in advance everyone
Old Dec 31, 2007 | 07:05 AM
CRX Toad's Avatar
Default Re: OEM or Mugen RTA bushings? (wickedEFguy)
I'd stick with the OEM replacements. They are modeled to to similar to the Mugen ones.
I justed pressed old ones out pressed new ones in on every set that I have done.
Old Dec 31, 2007 | 07:46 AM
Default Re: OEM or Mugen RTA bushings? (CRX Toad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote">I'd stick with the OEM replacements. They are modeled to to similar to the Mugen ones.
I justed pressed old ones out pressed new ones in on every set that I have done. </TD></TR></TABLE>
Did you have to press out the old metal sleeves as well?
One last thing...
Which number is it or do you know what the part number is?
Old Dec 31, 2007 | 07:54 AM
CRX Toad's Avatar
The new ones I have gotten all come with the metal ring around them from Honda. So i pressed everything out. I would verify with Honda or have part in hand before pressing. That is my experience.
I am pretty sure that all Civic's/CRX's are the same. I don't have part number. I just call up dealership and make them find it. I figure that is what they get paid to do. Part # 52385-S21-003
https://honda-tech.com/zero...age=1
Old Dec 31, 2007 | 07:57 AM
zccr-xsi's Avatar
OEM bushing IMO i hear them mugen ones are hard as hell.
Old Dec 31, 2007 | 07:59 AM
civicandy's Avatar
I'm using the ES bushings, and you can adjust the toe, but you need 2 people. The better solution would be to buy an adjustable compensator arm. Piece #15 in the diagram. I don't know who makes it, but I've seen them.
Old Dec 31, 2007 | 08:04 AM
harmonator84's Avatar
Default Re: OEM or Mugen RTA bushings? (civicandy)
So going in and replacing all your bushings to New OEM. Around how much would that cost?
Old Dec 31, 2007 | 08:46 AM
alscrx's Avatar
Default Re: OEM or Mugen RTA bushings? (harmonator84)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by harmonator84 &raquo;</TD></TR><TR><TD CLASS="quote">So going in and replacing all your bushings to New OEM. Around how much would that cost?</TD></TR></TABLE>
A few hundred bucks, I did my entire front end. All new bushings had to be pressed in.
They sell that expensive tool to press the RTA bushings in but not worth it if your doing one set. Anyone find another solution or tool for cheap or rent?
Old Dec 31, 2007 | 09:35 AM
Default Re: OEM or Mugen RTA bushings? (alscrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alscrx &raquo;</TD></TR><TR><TD CLASS="quote">
They sell that expensive tool to press the RTA bushings in but not worth it if your doing one set. Anyone find another solution or tool for cheap or rent?</TD></TR></TABLE>
So I just go to my dealer and tell them I want ALL new bushings. I bet thats going to be 300+ dollars.
Old Dec 31, 2007 | 09:39 AM
CRX_Banned's Avatar
* B A N N E D *
Mugen man. OEM is not cool anymore.
Default Re: (CRX_KING)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_KING &raquo;</TD></TR><TR><TD CLASS="quote">Mugen man. OEM is not cool anymore. </TD></TR></TABLE>
Well where do you pick up Mugen??
Old Dec 31, 2007 | 10:04 AM
CRX_Banned's Avatar
* B A N N E D *
Default Re: (harmonator84)
Well where do you pick up Mugen??</TD></TR></TABLE>
google.com &gt;SEARCH :Well where do you pick up Mugen?? I picked up a spark plug cover for $69.99+ TAX+ shipping+ handing
Old Dec 31, 2007 | 10:07 AM
CRX Toad's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_KING &raquo;</TD></TR><TR><TD CLASS="quote">Mugen man. OEM is not cool anymore. </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_KING &raquo;</TD></TR><TR><TD CLASS="quote">
Really, I have seen a couple of your most recent posts. Why don't you attempt to add something useful to this entire forum. CRX King will soon be CRX Banned at your current rate.
BTW the OEM is modeled after the Mugen.
Old Dec 31, 2007 | 10:08 AM
GSX 4G63T's Avatar
Default Re: (CRX Toad)
she is full of crap.
Old Dec 31, 2007 | 10:09 AM
Ass$nyper's Avatar
Pirate General...YARRRR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicandy &raquo;</TD></TR><TR><TD CLASS="quote">I'm using the ES bushings, and you can adjust the toe, but you need 2 people. The better solution would be to buy an adjustable compensator arm. Piece #15 in the diagram. I don't know who makes it, but I've seen them. </TD></TR></TABLE>ES bushing owner here as well, the job sucked but it helped a ton. I know some people feel OEM or mugens are better but any of them beat dead bushings for sure.
Old Dec 31, 2007 | 10:50 AM
Default Re: OEM or Mugen RTA bushings? (***$nyper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ***$nyper &raquo;</TD></TR><TR><TD CLASS="quote">ES bushing owner here as well, the job sucked but it helped a ton. I know some people feel OEM or mugens are better but any of them beat dead bushings for sure.</TD></TR></TABLE>
Here's my opinion:
Spherical &gt; OEM &gt; ES bushings
The ES bushing doesn't allow any like play the OEM does in cornering which will causes binding. Another thing is that you're very limited on adjusting toe on the tires. I don't know about you but I rather keep long life on my tires with OEM bushings versus new tires every couple thousand miles since my car is lowered.
Old Dec 31, 2007 | 11:06 AM
SIred91's Avatar
Rainman
Dont get spherical man....You will oversteer into a ditch...its only a matter of time.
I cant remember where, it was on Dseries, that the Mugen and Oem RTA bushings where just about identical. No one could tell the difference.
If in fact, that is true, just get OEM.
My nukka.....You commin over today homie?
Old Dec 31, 2007 | 11:17 AM
zccr-xsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote">BTW the OEM is modeled after the Mugen. </TD></TR></TABLE>
hows that?do u mean mugen is molded after OEM?
Old Dec 31, 2007 | 11:22 AM
CRX Toad's Avatar
Default Re: (zccr-xsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zccr-xsi &raquo;</TD></TR><TR><TD CLASS="quote">
hows that?do u mean mugen is molded after OEM?</TD></TR></TABLE>
Other way around....OEM was redesigned like Mugen.
Old Dec 31, 2007 | 11:26 AM
zccr-xsi's Avatar
Other way around....OEM was redesigned like Mugen. </TD></TR></TABLE>
oh yea i knew that but i was talking about the stuff its made with the mugen is a little stiffer rubber then the oem one.a honda one still gives u some kinda of movement.this will boildown to what type of ride comfort do u want.
Old Dec 31, 2007 | 11:28 AM
CRX Toad's Avatar
In that redesign the OEM was made a tad stiff too if I recall correctly. Not as stiff at Mugen.
Old Dec 31, 2007 | 11:31 AM
zccr-xsi's Avatar
kingsmotorsports sells they as a whole kit just like E/S does for the crx/civic.
now i owuld like to try the mugen shifter bushing i bet there alot better then the e/s ones but i cant find them as a set.
Modified by zccr-xsi at 12:47 PM 12/31/2007
Old Dec 31, 2007 | 11:45 AM
Zaakro's Avatar
if only Wes was still here
http://www.performanceforum.co....html
Old Dec 31, 2007 | 12:46 PM
Default Re: OEM or Mugen RTA bushings? (SIred91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">Dont get spherical man....You will oversteer into a ditch...its only a matter of time.
My nukka.....You commin over today homie?</TD></TR></TABLE>
Well if I ever decide to AutoX my car I do want some oversteer so some day when I'm rich I'll get the spherical bearings
Yeah I'll come over today, gotta run home first to change then I'll give ya a call. I'm off at 3
Draco
14
May 30, 2011 08:22 PM
DC2*Integra
Suspension & Brakes
Aug 21, 2008 02:40 PM
1999gs-r
Oct 6, 2006 05:34 AM
Jeff_B
40
Dec 20, 2005 08:29 AM
p1driftfiend
24
Jul 10, 2004 12:25 AM
