Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Odyssey Transmission
Old Dec 31, 2007 | 05:22 AM
jolt-tsp's Avatar
Default Odyssey Transmission
I'm trying to buy a spare transmission so I can have something to run while I rebuild my current one. Does anyone here know if a '04 Odyssey transmission will fit an '02. Most the parts seem to share the same part numbers, but I was hoping someone knew for sure.
I would be willing to bet this post gets no replies tho :-p
Old Jan 1, 2008 | 02:05 PM
jdmitr's Avatar
Default Re: Odyssey Transmission (jolt-tsp)
Should be very close. I would check the trans model # on the trans to see if they are the same. I would make sure all the solenoids and lines are in the same spots. But I would be surprised if they were different. I do know they changed the ECU in 02 for better shifting.
Old Jan 2, 2008 | 04:20 AM
jolt-tsp's Avatar
Default Re: Odyssey Transmission (jdmitr)
zOmg, a reply@!!!
I'll run through the part numbers one more time before I grab the '04. Thanks!
Old Jan 10, 2008 | 07:34 AM
FAST4DR's Avatar
Interesting. LMK what you find out. Wifes 03 JUST took a dump last night and we are in the process of trying to get Honda to cover it, even though we are at 87k. Since this is a WELL KNOWN issue with the 02 and 03, I cant see why they wouldnt, but who knows. I'm heading back up to the dealership in about 15 minutes...thinking good thoughts....
Old Jan 16, 2008 | 04:25 PM
cimo463's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jolt-tsp &raquo;</TD></TR><TR><TD CLASS="quote">I'm trying to buy a spare transmission so I can have something to run while I rebuild my current one. Does anyone here know if a '04 Odyssey transmission will fit an '02. Most the parts seem to share the same part numbers, but I was hoping someone knew for sure.
I would be willing to bet this post gets no replies tho :-p</TD></TR></TABLE>
How many miles are on it? Honda should replace the trans for you
Old Jan 20, 2008 | 05:14 AM
86si's Avatar
Default Re: Odyssey Transmission (cimo463)
02-04 are the same trans. 99-01 are a different trans and are covered by a warranty extension by Honda.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cimo463 &raquo;</TD></TR><TR><TD CLASS="quote">
How many miles are on it? Honda should replace the trans for you</TD></TR></TABLE>
02 and up are not under the warranty extension but if you complain to Honda they will atleast pay for the trans. and you will have to pay the labor.all it takes is a phone call to customer service and i guarentee they will help anyone with a transmission issue.
Old Jan 22, 2008 | 08:14 PM
OFEMA's Avatar
Hello All, I'm a new member who stumbled onto this thread from a motorcyle forum.
Fast4DR, you mentioned that the 03 Odysseys have a well known transmission issue? Can you describe it? I think our 03 suffers from it too.
thx much.
Old Jan 23, 2008 | 06:08 AM
86si's Avatar
Default Re: Odyssey Transmission (OFEMA)
all odyssey's have issues up to 04. usually you'll get a check engine light with a trans code and harsh shifting or slipping.
Old Feb 18, 2008 | 10:03 AM
OFEMA's Avatar
Default Re: Odyssey Transmission (86si)
jolt, i apologize for hijacking this thread
86si, thx for the info. we had that tranny thing taken care of with the recall, but within the last 2 years, the transmission feels like it's not up or down shifting quick enough.
Old Feb 24, 2008 | 05:13 PM
kinglarry's Avatar
having problems with 02 odyssey transmission. from reading others treads i see that trans problems are common issue. someone suggested calling honda customer service. is that my local dealer or corp?
Old May 16, 2008 | 08:17 AM
shortlid's Avatar
Default Re: (kinglarry)
Did the first gen Ody. have this issue like a '98 with the four cyl.??
99blackdc2
Transmission & Drivetrain
Oct 5, 2012 06:54 PM
91LS_CRX
Northwest
10
Sep 30, 2012 09:53 PM
civicracer167
Oct 31, 2009 06:32 AM
