no sound!!
Old Dec 30, 2007 | 10:24 PM
RotaryPWR's Avatar
Default no sound!!
I've got a panasonic head unit, panasonic door speakers, and JBL rears. I've noticed that when my trunk is open, the speakers work fine, and the music plays normally. However, when the trunk is closed, the speakers usually do not work. The head unit still displays the radio station or cd track, etc, but there is absolutely no sound.
I researched a bit here on H-T and found that this could be due to a ground issue. My left speaker wire is loose because it was simply tied on as opposed to soldered (as i did on the right speaker). Ya, I know I should solder it too, but I ran out of time when i was doing it. Is it possible that this lack of sound is due to the wire touching my trunk lid strut and grounding the whole system? If not, what could it be?
Thanks in advance.
Old Dec 30, 2007 | 10:30 PM
jesseman's Avatar
Default Re: no sound!! (RotaryPWR)
I 'll bet my left nut that when you close the trunk, the spring crossbar just clips the speaker magnet and either touches the contacts on the speaker or pushes them into something that will cause it to ground out.
Old Dec 31, 2007 | 05:31 AM
White Smoke's Avatar
i my honda
Global Mod
Do you have your connections at least tapped up? It does sound like you are grounding one of the speaker wires causing the HU to go into a safety mode.
Old Dec 31, 2007 | 08:02 AM
fcm's Avatar
fcm
Old Fart
Ditto both the above^^^, although I wouldn't bet either of my nuts on anything. 94
Feli
Audio / Security / Video
Feb 28, 2010 06:03 PM
HtxPrelude2K
Sep 2, 2008 06:21 PM
The1Ash10
Dec 19, 2005 02:40 PM
cleofis
Jun 8, 2004 10:03 AM
osuPrelude
Jan 20, 2003 07:27 PM
