Tire question?
Old Dec 30, 2007 | 08:51 PM
CRX91SE's Avatar
Default Tire question?
Ok on my crx i had 205/40/17 and i picked up a set if 15'' since then, i want to put on the azenis at 205/50/15? Is there a chance they will rub? I dont think the will cause i had 17'' and the didnt? Im looking to pick up tires in the next week..
Thanks
-Chris
Old Dec 31, 2007 | 01:44 PM
CRX91SE's Avatar
Default Re: Tire question? (CRX91SE)
i just dont want to have to roll my fenders?
the tenzo is 35mm offset
and it says that the 15'' maglite is 40mm offset you think it would rub?...
Old Dec 31, 2007 | 02:20 PM
welfarepc's Avatar
205/50R15 is a pretty fat tire
i run 195/45R15 and i wish it was slimmer.. (mine dont even come close to rubbing)
the 15's will have a smaller diameter than the 17's you used to run by 1.63%.
so they should fit
you might wana check into the offset tho
Old Dec 31, 2007 | 02:45 PM
turboZChatch's Avatar
Default Re: (welfarepc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by welfarepc &raquo;</TD></TR><TR><TD CLASS="quote">205/50R15 is a pretty fat tire
so they should fit
you might wana check into the offset tho</TD></TR></TABLE>
205/50/15 DD with no rub on different cars for 4yrs......you'll be fine with them
Old Dec 31, 2007 | 06:12 PM
CRX91SE's Avatar
Default Re: (turboZChatch)
i hope they fit...
Old Dec 31, 2007 | 06:23 PM
CRX Toad's Avatar
I have 205/50/15 lowered and have no rub issues. Really depends on that offset of the wheel
Old Dec 31, 2007 | 06:29 PM
RaceInspiredMS-CRX's Avatar
I dont think they will. Also depends on how low your car is.
Old Dec 31, 2007 | 07:43 PM
SIred91's Avatar
Rainman
Default Re: (RaceInspiredMS-CRX)
You will be fine with the 35 offset..not sure about the 40.
Old Dec 31, 2007 | 09:07 PM
CRX91SE's Avatar
Default Re: (SIred91)
about 40 off set..
also im running 195/60/15 Falkin 502 on the front, and i want to put the 205/50/15 Falkin 615
Old Dec 31, 2007 | 09:57 PM
CRX91SE's Avatar
Default Re: (CRX91SE)
edit
Old Dec 31, 2007 | 10:13 PM
CRX91SE's Avatar
Ok the 17'' is actually 42mm and the 15 is 40 so does this work with the 205's
Old Jan 1, 2008 | 02:31 AM
welfarepc's Avatar
hey what do you know, thats exactly what i said! haha
Old Jan 1, 2008 | 05:44 AM
fireant's Avatar
It really depends on how low the car is and what the camber is set to.
Old Jan 1, 2008 | 07:13 AM
snowseeker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX91SE &raquo;</TD></TR><TR><TD CLASS="quote">Ok the 17'' is actually 42mm and the 15 is 40 so does this work with the 205's
Whos Tiffany? Sounds hot!
Old Jan 1, 2008 | 09:11 AM
CRX91SE's Avatar
Default Re: (fireant)
Ok well im going to check how much room i have with the tires i have on now.. turn the wheel both ways and such..
Old Jan 1, 2008 | 09:57 AM
Crx Jimmy's Avatar
you will be fine I have run 225/45/15's without rubbing
Old Jan 1, 2008 | 04:44 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fireant &raquo;</TD></TR><TR><TD CLASS="quote">It really depends on how low the car is and what the camber is set to. </TD></TR></TABLE>
Bingo.
Depends on wheel width & offset, ride height, roll stiffness, and camber settings. Tire model and dimensions are only a couple of the many variables involved.
I've run 205/50-15 RT-215 Azenis on 15x7" +40mm wheels with no rubbing whatsoever on unmodified fenders, but I have a lot of roll stiffness (500lbs-in F/600lbs-in R with 22mm F/15mm R bars), a conservative ride height, and my suspension moves with the stock camber curve.
I've also run 225/45-15 Hankook RS2-Z212s on the same wheels with the same suspension settings, with only minimal rubbing of the fender liners (no metal bodywork was touched) at full steering lock.
Old Jan 1, 2008 | 05:01 PM
CRX91SE's Avatar
Default Re: (Targa250R)
It looks like i have about 1'' or inch and quarter of room from my side wall to this arm..
Old Jan 1, 2008 | 05:09 PM
Targa250R's Avatar
be professional
That really doesn't matter. I've never seen anyone with a clearance problem between the tire and knuckle or upper ball joint.
Like I said, you will not have any problems if you're using a 15x7" +40mm wheel with 205/50-15 Azenis, provided that you aren't running any adjustable control arms and have a reasonable ride height. Any rubbing will be minimal contact with the fender liners at full lock with some body roll.
Old Jan 2, 2008 | 04:26 PM
CRX91SE's Avatar
ya i do have 15x7''
Old Jan 2, 2008 | 04:35 PM
My_EFsedan's Avatar
i have 205/50/15 kumhos, no camber kits, no rub issues and my car is right over the tire. when i slammed it about half way from tire to rim awhile back..it was rubbing a lil bit when U turning..lol i notice a whole bunch of icons of CS..hahha
Old Jan 2, 2008 | 05:56 PM
CRX91SE's Avatar
Default Re: (My_EFsedan)
Ya i know cs is the ****!
Ok i have some pics i know the rear wont rub i have alot of room with the 195/55/15 on there now.. Here is a pic
Now here is the front, with 195/60/15 i have a feeling they wont rub but.. Look at the pic with the 205/50/15 "512" right beside it..
Old Jan 3, 2008 | 04:55 PM
CRX91SE's Avatar
TTT
JonathanCD5
Sep 6, 2014 08:45 AM
EJ1chevelle
Oct 20, 2007 08:14 AM
sprayedlude93
Mar 9, 2006 03:46 PM
Corporation
Sep 15, 2004 04:18 AM
Mike D
Jul 31, 2002 09:52 AM
