starting problem
Old Dec 30, 2007 | 08:12 PM
sam0218's Avatar
Default starting problem
i have a 91 civic dx and the battery died, no biggy thought i would jump it and it would be fine. well i jumped it, started up after a few cranks and it ran fine. ran it for about 40 mins and turned it off. i wanted to check tto see if the battery held the charge so i go to start the car again and the battery was dead it wouldnt crank. the battery is fairly new under a year old. what could be the problem? no cel
Old Dec 30, 2007 | 09:38 PM
crxcess's Avatar
Default Re: starting problem (sam0218)
does it run normally when you jump it? or are the headlights dim? if it is normal when running, you will need a new battery.
mysterysktr7
Jul 10, 2009 09:09 PM
smash fascism
Dec 3, 2005 07:58 PM
Tru
Apr 11, 2005 07:10 PM
darwinizm
Jan 8, 2005 08:34 PM
RTW DC2R
Mar 5, 2003 02:12 AM
