Pipe Bender Question?
Old Dec 30, 2007 | 06:12 PM
TVT_DESIGN's Avatar
Default Pipe Bender Question?
I'm looking to invest in a pipe bender for exhaust and intake work. I'll be using SS for the headers and exhaust and aluminum for the intake pieces.
My question is which type of bender is a good compromise between affordability and quality? I've seen some good non-mandrel benders that seem to not crimp the pipe. Is that because the pipe is too thick in the examples?
If a mandrel bender is my only option, please recommend a good company or product. This will be for small to moderate production
Old Dec 31, 2007 | 06:28 AM
dfoxengr's Avatar
Default Re: Pipe Bender Question? (TVT_DESIGN)
a non-mandrel bent exhaust is not going to get you much business in the aftermarket world. and mandrel benders are really expensive. your best bet is to buy a bunch of prebent pieces, and get good at fitting them together.
Old Dec 31, 2007 | 07:48 AM
dbiker207's Avatar
Default Re: Pipe Bender Question? (dfoxengr)
non-mandrel bent exhaust suck. most mandrel benders are like 15-20 feet long and like $20,000. like said before perfect your pipe fitting skills and buy prebent pieces to weld together.
to give you an idea of its size, this is a mandrel bender for up to 3" pipe
Old Dec 31, 2007 | 12:21 PM
danielm3's Avatar
Default Re: Pipe Bender Question? (dbiker207)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dbiker207 &raquo;</TD></TR><TR><TD CLASS="quote">non-mandrel bent exhaust suck. most mandrel benders are like 15-20 feet long and like $20,000. like said before perfect your pipe fitting skills and buy prebent pieces to weld together.
$20,000 will not get you a mandrel bender like that, the bender you have pictured is around $120,000.
A good manual machine will run at least 35k, but here is the fun part... tooling. For each size you want to bend add another 5 to 7k.
Old Dec 31, 2007 | 09:30 PM
TVT_DESIGN's Avatar
Ok then. Pre-bent pieces it is. I really need to hit that lottery...
Old Dec 31, 2007 | 09:56 PM
JDMs1eeper's Avatar
Default Re: Pipe Bender Question? (danielm3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danielm3 &raquo;</TD></TR><TR><TD CLASS="quote">$20,000 will not get you a mandrel bender like that, the bender you have pictured is around $120,000.
A good manual machine will run at least 35k, but here is the fun part... tooling. For each size you want to bend add another 5 to 7k. </TD></TR></TABLE>
PM'd ya
Old Jan 1, 2008 | 12:29 PM
ismkv8s's Avatar
Default Re: (TVT_DESIGN)
look for used equiptment! I just found a nice one for 9,000, now I'm tring to talk my boss into it forthe new year. I talked him in to the icengineworks header system and a tubing roller but I think I will have a hard sell with this one because we don't build that many exhaust systems.
Old Jan 1, 2008 | 10:26 PM
cua0's Avatar
you'd be surprised how many people will pay out the *** for non-mandrel bent pipe.
the biggest problem with mandrel bent exhaust systems is that unless you cnc it for each vehicle for a precise fit, you are stuck doing the cut & weld ****, that's fine for high dollar systems where you can actually charge out enough to cover your welding & fitup time.
a decent radius bender is still around $20k including tooling, and if you're good at it you can make radius bends that will be very very close to the performance of a mandrel system.
my dad is a expletiveing artist with his radius bender, the only really bad ones are the tight radius 90's where you have to make an S, that's expletiveing awful.
Old Jan 2, 2008 | 02:24 PM
six sigma racing's Avatar
here is my paper weight i boughty 7 months ago.. i still can't afford to buy tooling yet.. but one day
mthao_22
Dec 1, 2013 04:51 PM
Desir Performance
Welding / Fabrication
Jun 16, 2007 09:41 PM
hondaapi
Jul 4, 2006 08:21 PM
B16CRXT
Mar 14, 2005 02:34 PM
