brake booster and MC question.
Old Dec 30, 2007 | 04:24 PM
chinochanginc's Avatar
Default brake booster and MC question.
Im swapping the rear drums on my 94 civic Lx for gsr rear discs.
I know i need a 40/40 prop valve to get the full potential of the rear discs. My mechanic was asking about the MC. He wanted to know if i should swap the MC for one off of a car that came with rear discs. what i need to know isthe size of the Master cylinder on a civic lx and the size for a 39 - 00 gsr.
another thing. is the brake booster the same size on the 94 lx and the 94 or 95 si?
~chino
Old Dec 30, 2007 | 05:51 PM
blu eg22's Avatar
Default Re: brake booster and MC question. (chinochanginc)
Your lx should've come with a 13/16" MC. You can go w/out swapping the MC...just depends on if you're upgrading the fronts and your preference on pedal feel. I think the gsr has a 1" MC but you might have to use the gsr booster as well. If you do swap MC's I'ld suggest the 15/16" MC. You can find one off a 91 ex sedan or any 92-95 ex coupe.
And the booster is 9" on the lx and si/ex models.
Old Dec 30, 2007 | 07:54 PM
Default Re: brake booster and MC question. (blu eg22)
k. the MC on the 94 Lx and Si are the same according to the part numbers on Majestic honda. so im just going to swap the Prop valve then.
thanks
Old Dec 30, 2007 | 07:58 PM
i was just thinking.. what is the size of the stock LX rotor (front)
cux the integra ones are about 10 inches.. that woulndt be balanced if i had 9 inch rotors up front and 10 in the back....
Old Dec 30, 2007 | 10:02 PM
blu eg22's Avatar
Default Re: (chinochanginc)
I think the lx front rotors are somewhere around 9.3" and the fronts on the teg should be 10.5". I'm not sure about the teg rears. If you're just going to swap to rear disc then just get the 4040 prop and you'll be good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chinochanginc &raquo;</TD></TR><TR><TD CLASS="quote">k. the MC on the 94 Lx and Si are the same according to the part numbers on Majestic honda. so im just going to swap the Prop valve then.
The MC's on all 92-95 civics are interchangeable b/c they all have the same brake booster. The stock MC is different depending on your trim level i.e. the ex coupe has the 10.5" rotor and larger caliper so it has a 15/16" MC.
Old Dec 31, 2007 | 01:37 AM
Default Re: (blu eg22)
yea the intega rears are about 10 inches.
if i had 9 inch discs in the front and 10 in the back. wouldnt that throw off the balance?
Old Dec 31, 2007 | 01:59 AM
pythoner's Avatar
the GSR is 15/16 and the mounting ears (brake booster side) are turned the wrong way but I THINK a 91 EX sedan is right
DSMAddicted
Apr 5, 2012 06:20 AM
malubawla
Apr 5, 2006 03:05 AM
95DXPhiladeph
Apr 14, 2004 10:46 PM
NW94RS
Jan 15, 2004 11:05 PM
2camsaam
Jul 19, 2003 09:24 AM
