h22 civic problems...
So i bought a h22 96 civic ex with some problems... It was a deal i could not let pass..
.. But anyway here are some problems that it has and i am curently trying to figure out...
It idles very high 2300 and it wont drop even it i let it warm up..
VTEC wont kick in.
Speed Gague doesn't work...
So im trying to get it running right... what should i start with?
Someone told me that i need a secondary o2 sensor..... and others told me that i nedd a new oil pump...
by the way it is a 96 civic ex, and it is a h22 and it is running with a p13 ecu...
.. But anyway here are some problems that it has and i am curently trying to figure out...It idles very high 2300 and it wont drop even it i let it warm up..
VTEC wont kick in.
Im not familiar with the ecu specs and such. but the reason your vtec is not working is you vss (vehicle speed sensor) is bad which is also why your speedo doesnt work. Car must be above certain speed b'fore vtec works, with other requirements of course. Have you adjusted the idle screw?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wicked_b16eg »</TD></TR><TR><TD CLASS="quote">show me one thing verifies that speed plays a factor..... smell
Show me one thing that verifies you've ever looked in a service manual, its there. Vtec needs the correct minimums of RPM, vehicle speed, coolant temp, mani press. and oil press.
</TD></TR></TABLE>Show me one thing that verifies you've ever looked in a service manual, its there. Vtec needs the correct minimums of RPM, vehicle speed, coolant temp, mani press. and oil press.
okay i can help you with this, ive had the same car
first to get rid of the secondary o2 sensor, get a chipped p28 and conert to obd1
cover your throttle body while the car is running, blocking off air, if the car continues to run you have a leak in your intake manifold at the tb or head
what kind of ecu are you running now? what kind of injectors? peak and hold? do you have a resistor box?
i will try that.. and i am running stock h22 injectors... and i have a p13.... so i will have to get a p28 for my car to run right?
the engine is basically 92-95 obd1 h22 and its mostly stock with headers and intake....
Im not sure how obd2 plays into your equation considering your car is a 96.
I also had problems with idle when I first finished my swap. Have you cleaned your FITV? IACV? Have you completely bleed your coolant system?
i have not cleaned those but when the swap was pulled from the car it was running perfect... i just swapped it to my car and it started acting up on mine.... now it is running on a obd1 chipped p13 ecu
Was this as soon as you started it like for the first time? I noticed you said chipped p13, depending on what program was used in tuning, they are options for idle rpm in the program, probably a long shot though. Something else just hit me though, what about the tps (throttle position sensor)?
i did manipulate mine a lot. seemed to be trial and error, while the car was running, to get the correct setting. their is also a way to check the voltage of your idle. search and you should find it, i dont remember exactly how or what numbers you should get while testing.
apok408
Jan 7, 2004 02:39 PM
phatcivic99
Sep 18, 2002 06:55 PM
