Need help with my power windows..
Old Dec 30, 2007 | 02:59 PM
RARE_EG2's Avatar
Default Need help with my power windows..
To start, I have a Del Sol and of course they all come with power windows. Well, the other day I was driving and I rolled down my driver side window and as I went to roll it back up, it didn't go up. When I hit the switch to lower it, I can hear the motor, but when I hit the switch to roll it up, I hear nothing. I tried swapping out the switches and I still have the same action. Any ideas?
Old Dec 30, 2007 | 03:02 PM
z6hatchboy's Avatar
i say take door panel of and take a look around. Also is there a contact in the connector (regulator motor/switch) for the up action? Something may be wrong with contacts/connections. Thats all i can think of.
Old Dec 30, 2007 | 03:24 PM
EG2-Kermit's Avatar
There are 2 wires on the motor
Blue/White
Blue/Red
If going down, there must be 12V on the Blue/White
If going up, there must be 12V on the Blue/Red
If the up-function doesn't have 12V on the wire, you can put there 12V with a separate wire on the Blue/Red (use a 20A fuse between the wire and battery)
If it goes up, you have a problem in the cable or the control unit.
If it doesn't go up, youre motor may be damaged or a problem with the connector
Old Dec 30, 2007 | 04:10 PM
jays01's Avatar
Default Re: (EG2-Kermit)
when i work at woodfin honda junkyard i had to pull window motors all the time and check them befor selling they way we did that was just take a two wire positive and neg from that battery and touch the wire on the motor if it spins one way then i would switch the wire and see if it spun the other way
if you motor is bad the you should be able to use the motor from a 92-95 civic, 94-01 integra, and of course 92-98 delsol
if you motor works then it could be you window regulator is bad
Old Dec 30, 2007 | 06:58 PM
soless's Avatar
96civic808
Dec 13, 2015 05:35 PM
pisetup
32
Oct 12, 2014 08:52 PM
spnej1
16
Mar 3, 2008 06:32 AM
civic_stunna
17
Aug 18, 2004 05:11 AM
jdm5lughatch
10
Feb 21, 2004 07:32 PM
