Suspension & Brakes Theory, alignment, spring rates....
eg trailing arms on teg
Old Dec 30, 2007 | 02:26 PM
low91teg's Avatar
Default eg trailing arms on teg
Like the title says i was wondering if you guys could help me out i was taking off my lca's well trying to get them both off and the bolt under the disc break snapped. i tried to drill it out but my drill bits i bought will not drill through the bolt.
My actual question is if I buy some rear trailing arms and breaks that came off of a eg civic are they the same size as my brakes and trailing arms on my 95 teg. i can provide pics if needed.
thanks for any help you can give !!
Old Dec 30, 2007 | 11:34 PM
doubleshotz's Avatar
Default Re: eg trailing arms on teg (low91teg)
Yes, the Civic's rear trailing arms will bolt right on.
If the Civic came equipped with rear disc brakes, yes, they are identical.
Old Dec 31, 2007 | 07:25 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by low91teg &raquo;</TD></TR><TR><TD CLASS="quote">My actual question is if I buy some rear trailing arms and breaks that came off of a eg civic are they the same size as my brakes and trailing arms on my 95 teg.</TD></TR></TABLE>
Yes, they are the same trailing arms and brakes (9.5" solid rotor w/Nissin 7CLP13S "R3" caliper). The only thing that may pose a problem is the lack of an ABS sensor ring on the hub; not all '92-95 Civics with rear disc brakes had ABS. You could just swap the hubs around.
However, it's a bit drastic to solve a broken bolt. If you don't have the tools to extract the bolt, why not take the arm to a machine shop or repair shop and have them remove it for you?
Old Jan 1, 2008 | 12:29 PM
low91teg's Avatar
yea i was thinking about doing that just trying to avoid paying some one else to do work on my car u know. I'm cheap what can i say lol.
thanks for the input guys i appreciate it.
eHMxhACk
Oct 19, 2013 05:53 PM
Mistermark
May 16, 2006 12:46 PM
Jmunk
Apr 17, 2005 10:27 PM
Do_Ster
Feb 11, 2004 02:44 PM
92hybridhhatch
Feb 7, 2003 09:46 AM
