new pistons ,rods E.T.C
ok this is my first major build i have an ls v-tec gsr head ls bottom and im about to buy pistons, rods, and a crank i want to know is their a certin length rod i have to buy or can i use everything i have??
p.s can i have the tourqs for the head,crank, e.t.c
CRANK
Stroke Journal width Journal Diameter
3.504 . 945 1.722
RODS
length5.394 , big end diameter 1.890", big end width .935", pin diameter.827"
PISTONS
Displacement
109.68"
1798.03
Finished Bore
3.189"
81.00
Stroke
3.433"
87.20
Rod Length
5.429"
137.9
Comp. Height
1.185"
30.09
Compression
10.10:1"
10.10:1
Wall Clearance
0.0030"
0.076
Wrist Pin Diameter
0.827"
21.0
Top Groove
0.060"
1.5
2 nd Groove
0.060"
1.5
Oil Groove
0.158"
4.0
CRANK
3.504 . 945 1.722
RODS
PISTONS
Displacement
109.68"
1798.03
Finished Bore
3.189"
81.00
Stroke
3.433"
87.20
Rod Length
5.429"
137.9
Comp. Height
1.185"
30.09
Compression
10.10:1"
10.10:1
Wall Clearance
0.0030"
0.076
Wrist Pin Diameter
0.827"
21.0
Top Groove
0.060"
1.5
2 nd Groove
0.060"
1.5
Oil Groove
0.158"
4.0
Your rod length will be determined by the crank you use.
LS crank has a longer stroke therefore you'll use LS rods since they are shorter.
GSR/ITR crank has a shorter stroke so therefore you will use GSR/ITR rods since they are longer.
Since your doing an LS/Vtec you'll be using the 89mm crank, im not sure why you listed the GSR/ITR crank (87.xx)
Ali
Ali
ok... the crank im geting says its for B18A/B B20B/Z Honda Eagle Race Crank Acura Integra u can check it out on e-bay (((Item number: 200186667176))).\
but i was wondering if anyone can tell me the tourqes for the head (gsr), rod bolts,crank, and flywheel.......
Well in your post you first list:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbohatch101 »</TD></TR><TR><TD CLASS="quote">
CRANK
Stroke 3.504 </TD></TR></TABLE>
Which is 89.0016mm
But then you state
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbohatch101 »</TD></TR><TR><TD CLASS="quote">Stroke 3.433"</TD></TR></TABLE>
Which is 87.1982mm
And for rods you first list
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbohatch101 »</TD></TR><TR><TD CLASS="quote">RODS
length 5.394 </TD></TR></TABLE>
then
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbohatch101 »</TD></TR><TR><TD CLASS="quote">Rod Length 5.429"</TD></TR></TABLE>
So what do you have?
Ali
CRANK
Which is 89.0016mm
But then you state
Which is 87.1982mm
then
Ali
If you bought the crank that you listed tha you have an LS sized crank therefore you'll need LS sized rods.
Also, for the torque specs purchase a helms manual. This will be by far your best investment ever.
http://www.helminc.com
BTW, do you plan on boosting this motor?
Ali
Ali
of course im puting invalves, valve springs cams, pistons, rods, crank, block guard, im fully building it then ill run like 15-20 pounds of boost so do u think every thing i have for the block will b ok???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbohatch101 »</TD></TR><TR><TD CLASS="quote">of course im puting invalves, valve springs cams, pistons, rods, crank, block guard, im fully building it then ill run like 15-20 pounds of boost so do u think every thing i have for the block will b ok???</TD></TR></TABLE>
i think you don't know what you're talking about and posted up copied random information that doesn't jive together, as proven by Ali
I think you should spend some more time reading. The all motor forum (https://honda-tech.com/zeroforum/44) would be a great place to start and ask questions. I am for sure not an expert, but you do not seem to know what you need to put together this motor. I feel once you do a bit of reading you will know more or less what you need for the build.
Give it a few months of due diligence and you will be rewarded.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WinningNinja »</TD></TR><TR><TD CLASS="quote">Give it a few months of due diligence and you will be rewarded.</TD></TR></TABLE>
QFT.
I research motor builds and related stuff every now and then for a while now, and I still don't think I have the knowledge to put a build together without doing a ton of more research. There's a lot of small stuff out there that can and will make a big difference.
And as Graf-fiti mentioned it does look like your just copying and pasting info.
What rods do you plan on using?
What pistons do you plan on using?
Do you plan on atleast honing the block because it seems as though your keeping the stock bore?
IMO, if your doing a full build then why not bore and sleeve, or alteast bore .25 over and use oversized pistons so you have fresh cylinders that are shaped properly.
What size turbo do you plan on using? 15-20 pounds is not a little.
Ali
Modified by PrinceAli132 at 3:59 PM 1/4/2008
QFT.
Ali
I agree with winningninja, if you dont know what parts to get or even the torque specs your not ready to build a motor and should probably do some more research.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrinceAli132 »</TD></TR><TR><TD CLASS="quote">
QFT.
I research motor builds and related stuff every now and then for a while now, and I still don't think I have the knowledge to put a build together without doing a ton of more research. There's a lot of small out there that can and will make a big difference.
You are correct Ali. Experience definitely the key here. Why waste all the $$$, only for the motor to be less than reliable. At least the DD can help him pick out parts that will work together.
QFT.
ok guy i said this is the first "fully built motor im putting together" i have had ls-vtec turbo in my hatch running 10pounds of boost and it ran 13.86 at the track i have since took the turbo off and i am now gonna build it but no i havent took a motor apart like that.. the most i did is the ls -vtec conversion and my car still runs perfict till this day and ive had that set up for abot a year and a half so i do know a little but i am gona hone the block and im useing arias 81mm forged pistons with eagle i beam rods and eagle crank, block guard crower cams valve springs e.t.c i do know a little...
freitasfamily09
Jul 16, 2009 08:29 AM
jeremy.
23
Apr 27, 2005 02:20 PM
