Brake light problems....not so bright. Help!
Old Dec 30, 2007 | 01:12 PM
Mr.Chow's Avatar
Default Brake light problems....not so bright. Help!
So I'm back into hondas with my newly found 95' Hatchback. jdmb16, nice susp., brand new paint and corner panels...baby's minty fresh.
I was driving today in front of a buddy of mine, whom when we stopped at his place informed me that my passenger side brake light was substantially dimmer than the driver's side. This being something one can be pulled over on makes it a problem.
He thought it was a relay problem or something. I'm pretty sure something like this wouldn't just be a bulb. Any ideas?
Thanks!
Old Dec 30, 2007 | 01:18 PM
z6hatchboy's Avatar
Had the exact same problem with mine. I took the pass. tail light out and found it was full of water, drained it out and cleaned the the water+dirt mess out and it was a lot brighter.
Old Dec 31, 2007 | 08:51 AM
Mr.Chow's Avatar
Default Re: (z6hatchboy)
thanks I'll give that a try. Any other ideas?
Old Jan 2, 2008 | 01:25 PM
Mr.Chow's Avatar
Default Re: (Mr.Chow)
well its not that...anyone have any other ideas? Where's the relay?
Old Jan 5, 2008 | 12:41 PM
Mr.Chow's Avatar
TTT still need some help on this if possible
Old Jan 5, 2008 | 12:50 PM
random chaos 85's Avatar
its not a relay. did you try a new bulb? might be a ground problem or bad connection on that side
Old Jan 5, 2008 | 03:09 PM
ImportCracker88's Avatar
Press the brake pedal, and with it depressed, check for voltage to the bulb Green/White wire(should be battery voltage), then go to the other wire (Black)and then to a ground(should be .5volts or less), if u want to go further take u voltmeter and go from the Green/White wire to the Black wire(should be battery voltage).Make sure the bulb is working with the pedal depressed, otherwise the test above will be a waste.If u have any Q's on how to do this, E-mail me at Shstrumpetplayer@aol.com And please let me know ur results, I will then tell u wat is bad.
Old Jan 11, 2008 | 12:36 PM
Mr.Chow's Avatar
Default Re: (ImportCracker88)
thanks a lot guys I'll let you know.
theseeker4
Jul 6, 2015 06:45 PM
Jeff
Nov 22, 2006 03:45 AM
kwik eg hatch
Sep 10, 2004 08:23 AM
coot_er
Jul 29, 2004 02:30 PM
guttedEF
Oct 5, 2002 10:15 PM
