whats your harness connected to?
well i purchased my car with broken seatbelts and even worse seats (vinyl brown 88 std) and im looking at purchasing some new seats maybe some type r knockoffs or some si's. but imgonna get some new belts to and i wanted to know what your seatbelt harnesses are hooked up to in your 88-91 civic/crx? pictures are very helpful!
Modified by trevorjohn88ef at 1:26 PM 12/31/2007
as for the seats you would have to make custom brackets for it...and as for the seatbelts just go to the junk yard and find yourself some black seatbelts off of a 88-89 civic/crx that is mounted on the pillar and not on the door.
i have ones that are mounted to the pillar ad not the door but those are broke and im looking at a 4 point harness maybe depends. i just wanted to see whats people had attached their 4pt harness to in the back thats all.
[QUOTE= i just wanted to see whats people had attached their 4pt harness to in the back thats all.[/QUOTE]
I have a four point harness and mine is attached to my rear upper strut bar...will post pix later for you if you would like to have a look...give you and idea or two.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trevorjohn88ef »</TD></TR><TR><TD CLASS="quote">pics would be greatly appreciated
here they go...
</TD></TR></TABLE>here they go...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LatnKng »</TD></TR><TR><TD CLASS="quote">
here they go...
If you value your life at all I would move those to a more secure location. Or better yet atleast pick up a autopoer bolt in with a harness bar. a egay strut tower bar just doesn't ut it, and is deffinatly too low to mount the belts as well.
On a side note for some insight to the original question... Four points are not designed to be used in street cars and there are only 2 companys that make dot approved belts. One of my friends actually got his car towed for using takata harnesses when he was pulled over. I believe shroth (sp*) and corbeau make dot belts. Also try to mount the belts within + - 15 degrees from straight out from your shoulders to avoid from your back being crushed in the event of a accident.
here they go...
</TD></TR></TABLE>If you value your life at all I would move those to a more secure location. Or better yet atleast pick up a autopoer bolt in with a harness bar. a egay strut tower bar just doesn't ut it, and is deffinatly too low to mount the belts as well.
Dude. If you value your life at all, you will change your set up. That will kill you, and it looks like ****.
</TD></TR></TABLE>Dude. If you value your life at all, you will change your set up. That will kill you, and it looks like ****.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 »</TD></TR><TR><TD CLASS="quote">
Dude. If you value your life at all, you will change your set up. That will kill you, and it looks like ****.</TD></TR></TABLE>
Noted...thanks...i heard something about the harnesses crushing ones shoulder if mounted too low, but didnt think anything of it because i hadnt heard anyone mention it b4, but its good to get more people's opinion and concern on a set-up like mine...again...i will change the setup...thank you import2nr88 also...much appreciated.
Crazy_SI_T
Feb 19, 2013 08:54 PM
regime
Mar 26, 2004 02:02 PM
