quick clutch question
Old Dec 29, 2007 | 11:55 PM
gsrpedro's Avatar
Default quick clutch question
i have a 92 hatch wit a B16 tranny and wen u press the clutch u go all the way down and u let it go like a 1/2 inch and i grabs is there any way to adjust the clutch lower or higher like in the EF (cable tranny) on the hydro tranny??? thanks
Old Dec 30, 2007 | 01:00 AM
gsrpedro's Avatar
no one???
Old Dec 31, 2007 | 12:39 AM
gsrpedro's Avatar
damn this **** has like a million users and no one can help me??
Old Dec 31, 2007 | 01:04 AM
phyzJunkieCivic's Avatar
From: Dont You Just Love Lynn Cops, Boston MA, USMA
You probley can adjust it.
Look around were the clutch pedal is.
I dont know because i never adjust hydro before.
Old Dec 31, 2007 | 01:06 AM
NVM thats how I adjust my brake pedal :0
Old Jan 14, 2008 | 03:25 PM
D's_EK's Avatar
Default Re: quick clutch question (gsrpedro)
Bump! I also would like to know since I also need to adjust. My release point is way too high
Old Jan 14, 2008 | 03:30 PM
DCSportEJ1Civic's Avatar
Default Re: quick clutch question (D's_EK)
im pretty certain that the pedal is adjustable. but i dont think id change mine. if you adjust it too much you may not engage or dis-engage the clutch all the way and could cause gears to grind or your clutch to wear out prematurely.
Old Jan 16, 2008 | 05:09 PM
gsrpedro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D’s_EK &raquo;</TD></TR><TR><TD CLASS="quote">Bump! I also would like to know since I also need to adjust. My release point is way too high </TD></TR></TABLE>
i couldnt adjust the clutch but i adjust the clutch pedal its easy
Old Jan 16, 2008 | 05:15 PM
hondamark35's Avatar
i think the hydro's are 'spose to self adjust. the only adjustment i know of is the pedal freeplay.
you do have a stock clutch in it right?
you may want to check the fluid level and maybe even bleed the system.
Old Jan 17, 2008 | 07:55 PM
ludenoob99's Avatar
on a hydro system there reallyis no adjustments, the system does it by itself, if your clutch is grabbing too high it ususaly means the clutch is just about ready to be replaced because the clutch is getting thing so the throw out bearing has to move further before the pressure plate clamps the clutch.
Old Jan 20, 2008 | 07:46 AM
D's_EK's Avatar
Default Re: quick clutch question (ludenoob99)
Ever since I put in the clutch it's release point was always that high. I always heard you can adjust the pedal itself.
89civicsiowner
May 24, 2009 05:29 PM
kdsmonitor
Oct 13, 2008 07:35 PM
trianglegreg
Sep 29, 2005 09:50 AM
hatch4raceb16
Dec 1, 2003 04:35 PM
xtrafastcivic
Aug 29, 2002 03:25 PM
