Spark Plug Tube Seal (pic)
Old Dec 29, 2007 | 10:51 PM
EK_B's Avatar
Default Spark Plug Tube Seal (pic)
When replacing the VC gasket and the spark plug tube seals, do I need to use the extra grommets?
If so, where do they go? BTW this is for a 96 Accord LX 4 Cyl. Thanks.
Old Dec 30, 2007 | 01:26 AM
BlUAc's Avatar
Default Re: Spark Plug Tube Seal (EK_B)
naw thats it
Old Dec 30, 2007 | 07:50 AM
EK_B's Avatar
Are the three circle looking things supposed to go on top of eachother?
Old Dec 30, 2007 | 04:59 PM
EK_B's Avatar
Bump
Old Dec 30, 2007 | 05:28 PM
91h22cb7lx's Avatar
cant realy tell what your asking, if your asking about the the rubber guys on the right those should be for the washer for the top of the valve cover. the left ones go into the bottom of the valve cover, maybe start over and re-ask your question
Old Dec 30, 2007 | 09:47 PM
BLKFLSH's Avatar
Default Re: (EK_B)
The 4 O-rings (thin ones in the middle of your picture) go under the rockerarm assembly (part that holds the camshaft down) on the spark plug tubes. The thick round (large) circles go under the valve cover for the spark plug tubes. The small round grommets go under the valve cover nuts. And the largest gasket goes on the valve cover itself. There are write-ups on this, but I don't know if I have the links to them anymore. There is a how-to in the FAQ, but it would be better with pictures. Good luck
Modified by BLKFLSH at 12:58 AM 12/31/2007
Old Dec 31, 2007 | 05:08 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: (BLKFLSH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLKFLSH &raquo;</TD></TR><TR><TD CLASS="quote">There is a how-to in the FAQ, but it would be better with pictures.</TD></TR></TABLE>
one of the links you have to go to the 2nd page for pictures.
Old Dec 31, 2007 | 07:24 AM
EK_B's Avatar
BLKFLSH, thank you so much!
Old Dec 31, 2007 | 11:13 AM
BLKFLSH's Avatar
Default Re: (EK_B)
Just hope everything turns out ok, and I'm happy to help. I had to do this on my 92 Accord. The hardest part is setting the valves. It would help to have 3 hands for that job, and sadly I was forced to do with only two.
KevinVX
27
Nov 9, 2014 03:50 AM
zedjr
Jan 30, 2013 10:14 PM
Mysticalmotion
Sep 20, 2009 12:35 PM
shadow29485
Mar 23, 2008 08:25 PM
themorphious
Jun 3, 2006 12:14 PM
