ignition trouble on 1st gen b16a
Old Jun 28, 2002 | 05:22 PM
maskednegator's Avatar
Default ignition trouble on 1st gen b16a
i have a b16a in my crx and all the wiring is done, but if i put my hand on the top of the plug wire for cylinder #3, i can feel a pretty strong tapping. i can't feel it on the distributer, or where the wire meets it though. should i be worried? what do you all think is causing this?
Old Jun 28, 2002 | 07:18 PM
sleeper4dr's Avatar
Default Re: ignition trouble on 1st gen b16a (maskednegator)
i think we all need a little bit more info than that.....
is the engine running?? is this when you're cranking the engine? tapping at idle only??
DETAILS!!
Old Jun 28, 2002 | 07:38 PM
SuperJay's Avatar
gee I don't know, maybe you should put your tongue on the plug wire and see if it's still there?!
Old Jun 29, 2002 | 11:10 PM
damn...thanks for making me feel welcome here.
engine turns over, runs normally, vtec hits fine. new plugs, wires. wire makes that tap throughout rev range. doesn't sound like detonation. ecu is throwing code 6, due to broken ECT sensor.
Old Jun 30, 2002 | 05:48 AM
biggdogg's Avatar
I HAD THE SAME PROB ON MINE . i forgot to tighten down the plugs . make sure you did . mine pulsed real funny
Old Jun 30, 2002 | 07:51 AM
djay86's Avatar
[QUOTE]damn...thanks for making me feel welcome here.
QUOTE]
dont worry about, just shrug it off and continue to make a good name for yourself... everyone gets flammed here once in a while.
Old Jun 30, 2002 | 12:42 PM
Default Re: ignition trouble on 1st gen b16a (djay86)
true, true.
Revolemilbus
Jul 2, 2005 04:09 PM
matthevelli
May 10, 2005 06:51 PM
folta2169
Apr 10, 2005 12:35 AM
91sifreak
May 14, 2001 03:16 PM
