clutch cable issue
Old Dec 29, 2007 | 08:21 PM
redboy183's Avatar
Default clutch cable issue
ok i searched about my issue but all i found was guys snapping their clutch cables.......my problem is that i have both da and ef clutch cables and the da clutch cable bracket but i barelyyy put the cables in on the trans and through the bracket and its raised allll the way to the top and when i try to drive the car, it releases at the very top..basically burning my clutch.....so my question is what clutch cable bracket to use and what clutch cable for a 1990 ef with a b16 cable tranny??....need help quick please
Old Dec 29, 2007 | 09:40 PM
redboy183's Avatar
Default Re: clutch cable issue (redboy183)
nobody knows? i need help asap guys
Old Dec 29, 2007 | 10:42 PM
4g hatch's Avatar
i used my ef cable. did you adjust the cable all the way loose then hook it up, then tighten it till the clutch is where you want it
Old Dec 29, 2007 | 11:15 PM
honda4eva's Avatar
Default Re: clutch cable issue (4g hatch)
yeah ef cable will still work just need to adjust it
Old Dec 30, 2007 | 06:07 AM
gibsanez's Avatar
Default Re: clutch cable issue (honda4eva)
I'm using a DA clutch cable and I have plenty of adjustment.
Old Dec 30, 2007 | 07:42 AM
mjfubar101's Avatar
Default Re: clutch cable issue (gibsanez)
So let me understand this you have both a DA and an EF clutch cable and neither of them will give you the adjustment that you need? I ask because I am in a similiar situation with my EF, but I dont have a DA cable and am wondering if going to a DA cable would be the solution. I am in for the answer. Quick question what are the lengths of each cable?
Old Dec 30, 2007 | 11:42 AM
redboy183's Avatar
Default Re: clutch cable issue (mjfubar101)
i dont know the lengths but the da one is slightly longer but not by a lot at all...i got the ef on in there now on a da clutch bracket and its all the way tight i cant even adjust it its burning my clutch to high heavens and im about to cry because i have never seen anything like this before....neither cable simply fits at all....it just goes in wayyyyy at the top and cant be adjusted
Old Dec 30, 2007 | 11:48 AM
gibsanez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redboy183 &raquo;</TD></TR><TR><TD CLASS="quote">i dont know the lengths but the da one is slightly longer but not by a lot at all...i got the ef on in there now on a da clutch bracket and its all the way tight i cant even adjust it its burning my clutch to high heavens and im about to cry because i have never seen anything like this before....neither cable simply fits at all....it just goes in wayyyyy at the top and cant be adjusted </TD></TR></TABLE>
Correct me If I'm wrong, but you have the cable "tightened" all the way? As in, it's pulling the release arm up? Clarify what you mean by "all the way tight"
Old Dec 30, 2007 | 11:51 AM
redboy183's Avatar
yes the release arm is all the way up to the point where it cant go up anymore.....and when i try to drive the car the clutch releases all the way at the very top where its literally burning the clutch
Old Dec 30, 2007 | 12:07 PM
gibsanez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redboy183 &raquo;</TD></TR><TR><TD CLASS="quote">yes the release arm is all the way up to the point where it cant go up anymore.....and when i try to drive the car the clutch releases all the way at the very top where its literally burning the clutch</TD></TR></TABLE>
As far as I can tell, you're actually using the cable backwards. You need to loosen the plastic screw and move the release arm down, not up. Moving it down will make the clutch release "deeper" into your pedal throw.
Old Dec 30, 2007 | 12:14 PM
redboy183's Avatar
im not installing it backwards...what im saying is that either cable i use barely fits...meaning once its in...i cant adjust it at all.....so the only thing in the back of my mind is modifing the bracket bc i cant get any cable to work
Old Dec 30, 2007 | 12:34 PM
4g hatch's Avatar
how does the clutch pedal feel. does the clutch arm stay down like normal when the cable isnt hooked up
Old Dec 30, 2007 | 12:58 PM
redboy183's Avatar
the clutch pedal feels stiff as hell...but there is an aftermarket clutch im assuming (i do not know for sure never took the trans off)....but i just took off my clutch bracket and flipped it upside down and now there is only one bolt holding it down but i can this way adjust the cable...so if this works i am going to weld on and modify the clutch bracket bc i have no other solutions right now
Old Dec 30, 2007 | 06:29 PM
godruler's Avatar
don't reverse any brackets or mess with anything, just get the right parts. for it to work correctly and have the right amount of adjustment you need to use the parts for what ever drivetrain you are using. So if you have a b-series then you need to use the Da cable and tranny bracket. same goes if your running d-series drivetrain, you'd use all d-series parts. make sure you route the cable in a way that its not binding for any reason, adjust it to your liking and it should be set.
Old Dec 30, 2007 | 08:28 PM
redboy183's Avatar
Default Re: clutch cable issue (godruler)
dude thats my problemmmm i have the da bracket and cable but it dont fit...what so ever....i wish i knew which "parts" to get cause its drivin me nuts....soprry dont mean to sound like a smart *** im just really bummed/pissed
Old Dec 30, 2007 | 09:47 PM
4g hatch's Avatar
what clutch is it.
Old Dec 30, 2007 | 10:02 PM
grog's Avatar
Default Re: (4g hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gibsanez &raquo;</TD></TR><TR><TD CLASS="quote">
As far as I can tell, you're actually using the cable backwards. You need to loosen the plastic screw and move the release arm down, not up. Moving it down will make the clutch release "deeper" into your pedal throw.</TD></TR></TABLE>
^^^maybe what he is saying is you might be spinning the adjuster nut the wrong way, i remember having trouble with which way to turn it at first. just make sure the release arm is all the way down.
or could you have gotten the wrong cable maybe?
Old Dec 30, 2007 | 10:05 PM
burnout8488's Avatar
can you take any pictures? it still sounds like you're doing it wrong, but thats just me.
Old Dec 30, 2007 | 10:12 PM
grog's Avatar
Default Re: (grog)
the adjuster nut will be at the top of the threaded shaft when you are out of adjustment, I'm pretty sure
Old Dec 30, 2007 | 10:36 PM
eda6's Avatar
I had the same issue recently. my new ef clutch cable w/new da bracket was too short.
You could mod the cable like i did....
pull the cable apart here.
Take off a 1/2" at a time using a grinder to make the cut. For round 2,3,4, etc...you'll want to use a utility knife to cut the insulation.
use some linesman or side cutting pliers to remove what you just cut. use the knife to remove the outer layer of plastic that inevitabely melted. reinstall the cable in the car and eventually it will fit to your liking and you can adjust it properly.
Old Jan 1, 2008 | 07:05 PM
redboy183's Avatar
Default Re: clutch cable issue (eda6)
thanks for the pic help bro i did just that and it works great
Ef4doorwagon
Feb 19, 2015 01:10 AM
RanCRX
Apr 21, 2013 07:49 PM
EJ1Turbo
Dec 5, 2008 08:14 AM
latino honda
Nov 1, 2007 09:48 AM
whiteboy4life74
Aug 14, 2007 03:49 AM
