Bitch Pin
why? its not that hard to get out. the only time i couldnt get one out was cause some idiot tried to drill it out and the bit broke off inside the b pin i broke the linkage then decided to stop before i broke the tranny.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zccr-xsi »</TD></TR><TR><TD CLASS="quote">use a 4mm punch come right out.i think honda makes a tool for doing the job.</TD></TR></TABLE>
matco makes one. Makes things hella lot easier. I tried every method, ac bolt, punch, c-clamp trick, but I ended up having to order this tool:
took 5 seconds and 2 hits with a BFH and it was out.
http://www.matcotools.com/Cata...51164
you can also use like a 4mm small socket on an extension. or an allen head bit for a bit driver on an extension. just find a size that fits perfect and use it, no need to go and buy a new punch. you can also use the c clamp trick w/ the socket or bit.
and plenty of those. haha i hate those bitch pins still.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GroundZer0 336 »</TD></TR><TR><TD CLASS="quote">you can also use like a 4mm small socket on an extension. or an allen head bit for a bit driver on an extension. just find a size that fits perfect and use it,</TD></TR></TABLE>
done this too works very good.heres a tip when u get it out next time u put it back in find a bolt that fits that hole nice and perfect and put a nut on the other end and tighten it down good.so ull never have to deal with the ROLL PIN<<(proper name)
again.
again.
MattD@Stoptech
Jun 16, 2005 04:26 PM
CRX-RX
10
Mar 23, 2004 01:36 PM
