need some tire info
Old Dec 29, 2007 | 02:48 PM
grandam's Avatar
Default need some tire info
I just picked up my set of JDM sprint hart rims. they are 14x6 and a +40 offset, I am going to be using these on a 2.5" drop, i am just wondering the tire size that the civic uses is 185-65-14 will there be any rubing issues
Old Dec 29, 2007 | 04:43 PM
old man neri's Avatar
What car is this for?
Old Dec 30, 2007 | 02:24 PM
grandam's Avatar
Default Re: (old man neri)
sorry I forgot to mention they are going on a 1997 civic hatch
Old Dec 30, 2007 | 02:35 PM
I am guessing you should be okay. From my understanding that wheel/tire combo is essentially a stock set up.
you getting a camber kit or just a straight drop?
Old Dec 30, 2007 | 04:40 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: need some tire info (grandam)
That's the right tire size; you can also use 195/60-14, for which there are more (and better) tire choices.
If it rubs, it's because of the drop, not because of the tire size. So if it does, do something about the cause of the problem; don't try to compensate by using the wrong tire size too.
Old Dec 30, 2007 | 07:57 PM
grandam's Avatar
Default Re: need some tire info (nsxtasy)
I have the Skunk2 front and rear camber kit, so yeah would be like a drop on the factory size rims all that is different is that I am using a aftermarket rim
chas2429
Aug 8, 2017 05:22 PM
xero_xero
Dec 30, 2012 08:08 AM
88'CRXsi
May 7, 2009 02:17 PM
jdmcrx_echelon
May 30, 2007 05:04 PM
blackdc5
Oct 12, 2003 02:33 PM
