92-95 cd player removal...
Old Dec 29, 2007 | 02:21 PM
jonathan13's Avatar
Default 92-95 cd player removal...
i need to get my cd player out before i sell my 95 civic.. im sure this topic has probably been covered but i cannot find the right word combination to find any topics on this. any help or links will be greatly appreciated. thanks
Old Dec 29, 2007 | 02:59 PM
B18C_EJ8's Avatar
Are you pulling the factory CD Player? Or is it an aftermarket unit?
If it's aftermarket, you'll need to use the removal keys that came with the radio. "Removal keys" you ask? They're the little strips of metal that you will need to slide down the sides of the radio which release the clips holding the deck in the mounting "cage".
Old Dec 29, 2007 | 03:14 PM
jonathan13's Avatar
Default Re: (B18C_EJ8)
it is aftermarket and i know exactly what you are talking about.. so there wont be any screws holding the cd player in correct? just the retainer clips and i can use those removal tools and slide it right out? i appreciate the info
Old Dec 29, 2007 | 05:19 PM
B18C_EJ8's Avatar
Well, there really should be a screw holding the unit in, but most of the time, people don't put backstraps in, so no, there are probably no screws holding it in.
If you insert the keys, and you can't pull it out, it may be backstrapped behind the radio.
Old Dec 29, 2007 | 10:56 PM
jonathan13's Avatar
if it is how do i get it out because it was professionally installed so it is very possible that has screws holding it in from the sides.
Old Dec 29, 2007 | 11:46 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: (jonathan13)
try the keys first.
Old Dec 30, 2007 | 05:32 AM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonathan13 &raquo;</TD></TR><TR><TD CLASS="quote">so it is very possible that has screws holding it in from the sides.</TD></TR></TABLE>
Not in a 92-95 Civic it's not.
Old Dec 30, 2007 | 07:26 AM
fcm's Avatar
fcm
Old Fart
This may help... http://www.installdr.com/Insta...7.pdf
It is for the removal of the stock HU but it is the same process to access the back support for an aftermarket HU, [if there is one].
It is very unlikely the screws are in the side of the HU, [but not impossible], more then likely it will be a single screw through the stock back support into a "L" shaped piece of back bracing bolted to the back of the HU. 94
Old Dec 30, 2007 | 10:01 AM
patric8332's Avatar
Default Re: (fcm)
thanks so much for all the information
Old Dec 30, 2007 | 11:15 AM
fcm's Avatar
fcm
Old Fart
Default Re: (patric8332)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by patric8332 &raquo;</TD></TR><TR><TD CLASS="quote">thanks so much for all the information </TD></TR></TABLE>???????? 94
fito22
Honda Civic (2001 - 2005)
Jan 17, 2007 05:12 PM
george34
Audio / Security / Video
12
Aug 28, 2006 02:55 PM
uncle
Dec 31, 2003 11:21 AM
kingpen
Jan 15, 2003 01:45 PM
