crx si car harness question
Old Dec 29, 2007 | 11:21 AM
crxbomb's Avatar
Default crx si car harness question
I installed a 91 crx si car harness and engine harness into a 88 crx hf, i had to replace the relay going to the starter just to get the engine to turn over and at this point i cant get the engine to fire. I had to replace the engine harness and the car harness because they were both jacked up and I wanted to start with a virgin harness so I will know that the job is done right. I have an obd1 b18a1 motor with a b16 head and I did the conversion to the engine harness myself so I am confident it is done right. I also installed a jumper harness i purchased off ebay. My question is- Are there any relays or resistor boxs or anything on the car harness that could be bad and cause the engine not to fire? Keep in mind that I got the harness out of a junk yard so there is no telling how long it has set up.
Old Dec 29, 2007 | 03:51 PM
sirtef9's Avatar
Default Re: crx si car harness question (crxbomb)
Its all SI car and motor harness?
Old Dec 29, 2007 | 05:51 PM
black0hatch's Avatar
Default Re: crx si car harness question (sirtef9)
are you getting spark and or fuel? check that first then go from there. i have done this twice too. also if you have a hf engine harness and a si body harness or visa versa its not going to run. it will plug in but not run. did you all your harnesses of the same car?
Old Dec 29, 2007 | 08:18 PM
crxbomb's Avatar
Default Re: crx si car harness question (black0hatch)
Its all si car and engine harness. i cut the sunroof and rear window wiper wires. I am using the si engine harness because i read in another forum that the hf engine harness does not work with the si car harness (driver side plug has different wire pinout). I know I converted the engine harness correctly, or as correct as the instructions I was using. By the way thanks for any productive feedback, I am so close to driving a sweet *** little built all-motor b18/b16 crx, I need just a little wire help. This might make me sound like an idiot, but I just learned how a relay actually works by taking it apart, any honda wiring information that I can learn will take me one step closer to full knowledge of my baby. p.s. honda-tech is the ****
Old Dec 29, 2007 | 08:25 PM
crxbomb's Avatar
Is it possible to get some type of assembly manual for my crx? Im asking because I would like to know what color wire does what on my car harness so I can untape the harness and remove any wires that will not be used so my wire work will have a better appearance. I dont have A/C, heater, clock, and many other options and I would like to correctly remove their wires from my car harness to elliminate leftover plugs.
Old Dec 30, 2007 | 11:44 AM
crxbomb's Avatar
no spark, no fuel
Old Dec 30, 2007 | 12:40 PM
is the fuel pump priming?
Old Dec 30, 2007 | 12:46 PM
crxbomb's Avatar
Yep, the fuel pump is priming. There is a plug left unattached locatd near the dash fuse box. It has 5 wires going into it one of which is a large geen/red wire. It looks like it might require a relay or something. Im gonna go scope out my friends 91 si and see what it plugs into.
91CRX-T
Aug 17, 2011 01:16 PM
bradennicely
Apr 25, 2010 04:36 PM
skidmarkroyalty
May 16, 2009 08:07 AM
Josue
Oct 2, 2005 10:01 AM
P.M.Coupe
Apr 13, 2004 06:19 PM
