A few wiring ?'s
as of right not my ls/vtec is obd0 ...i am wanting to go obd1.. but i need to replace my harness as well..i'm unsure to what harness would drop in and fit the best...i'm guessing the si
is yours an SI now? http://www.rywire.com, im running the obd0 Si harness with the obd1 conversion,
No harness will just drop right into your chassis except for your stock harness. What you can do is purchase a suitable OBD-0 --> OBD-1 Jumper harness or you can convert the ECU connection yourself.
i know i need a jumper harness..but i need a new engine and interior as well...i have a bunch of small electrical problems..my parking light come on when you turn the car on..my blinker signals are crossed..the car will shut off if u turn on the lights ...maybe a bad ground...the harness is garbage..i need to rewire the while thing,,,just need to know which harness...i can't find a dx ..and si are hard to come by as well.
well i guess i'm looking for the wrong thing on ebay...i did some more research ....i figured a harness from any one of these would work...right?
88-91Si16-1.6i
88-91CRX Si16-1.6i
90-93 Integra LS
90-93 Integra RS
90-91 Civic Si-R (EF-9)
90-91 CRX Si-R (EF-8/9)
88-91Si16-1.6i
88-91CRX Si16-1.6i
90-93 Integra LS
90-93 Integra RS
