need help what goes here??
I thought all of the B-series VTEC motors had an oil cooler between the filter and the block? IF thats the case then your missing the oil cooler and from the picture it looks like there is not one there. I'm pretty sure about that. I could be wrong. The heater core hoses come from the end of the block around the distributer area. One is off the thermostate housing and the other is in the head. Just block off the pipe that is coming off the coolant bridge.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboEK9Coupe »</TD></TR><TR><TD CLASS="quote">I thought all of the B-series VTEC motors had an oil cooler between the filter and the block? IF thats the case then your missing the oil cooler and from the picture it looks like there is not one there. I'm pretty sure about that. I could be wrong. The heater core hoses come from the end of the block around the distributer area. One is off the thermostate housing and the other is in the head. Just block off the pipe that is coming off the coolant bridge.</TD></TR></TABLE>
thats where that line goes on h-series, and some b series
looks like your missing it
I dont think they would put a heater hose provision under the intake manifold. Its in between the water pump and the thermostate. That would not be a good place for a heater hose.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THE GUY »</TD></TR><TR><TD CLASS="quote">It's for the oil cooler. Get a water rail for a LS and your good. If you need one let me know I have a spare.
got pics?
</TD></TR></TABLE>got pics?
You could always just pinch off the piece of tubbing and weld it shut. That would cost next to nothing and would be quick. Just stick it in the vice and clamp it shut then just weld the end of it together. Simple fix to your problem.
that is your heater return hose one comes from the side of the head and goes into the fire wall then one right beside it goes back to your motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skUnK2jdm »</TD></TR><TR><TD CLASS="quote">
got pics?</TD></TR></TABLE>
Will get them for you when I get back home.
It is NOT for the heater like people keep saying. I'll hit you up in a little bit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboEK9Coupe »</TD></TR><TR><TD CLASS="quote">You could always just pinch off the piece of tubbing and weld it shut. That would cost next to nothing and would be quick. Just stick it in the vice and clamp it shut then just weld the end of it together. Simple fix to your problem.</TD></TR></TABLE>
That is also a good way to cause a major leak. Why not spend $15-25 and do it right?
CO_CReX
Apr 29, 2007 06:44 PM
