P06 ecu on ls motor?!!?
Old Dec 29, 2007 | 06:46 AM
pmpm06's Avatar
Default P06 ecu on ls motor?!!?
so i just figured out my obd II turbo ls motor was running on p06 ecu...
how does it work like this since its outta non vtec obd I civic??
ive ran into a big mess where i think everythings been hacked around as u see a lot in this game...
could someone please help me out??
i'm replacing the obd II ls w/ a obd I today and i was hoping to have it running, but i dunno how this ecu is gonna work out...?
Old Dec 29, 2007 | 07:15 AM
97Ej6mike's Avatar
P06 ecu is for the D15b7 (if i remember correctly). Using a 1.5liter sohc fuel map to run a 1.8liter DOHC motor is not a good idea. That will run it lean.
Old Dec 29, 2007 | 07:35 AM
dohcdelsol93's Avatar
Default Re: (97Ej6mike)
it will run , it just wont have any power. as said before it will run lean becuase it has different ignition/fuel/timing maps and all that jazz.
Old Dec 29, 2007 | 08:44 AM
pmpm06's Avatar
so how was the kid i got the car from running the obd II motor on an obd I ecu?? wouldn't that require a conversion harness?? or not?
so if i convert the obd I motor to obd II by changing the crank gear and using my obd II injectors, dizzy, and oil pump i will still need to run off the obd I ls ecu?? will this require a jumper harness?
Old Jan 2, 2008 | 04:18 AM
Default Re: (pmpm06)
the only thing you need to run an OBD II car with an OBDI ecu is the conversion harness.
You won't need to swap out all that other crap.
Old Jan 2, 2008 | 08:32 AM
Relic1's Avatar
keep in mind that a P06 can be chipped to run a LS as well as the stock ECU or even better. (if highly tuned)
if you're boosted there is a good chance that it's chiped or you'd throw a CEL as soon as you built boost.
Old Jan 2, 2008 | 10:13 AM
i_am_a_black_man's Avatar
Default Re: (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">keep in mind that a P06 can be chipped to run a LS as well as the stock ECU or even better. (if highly tuned)
if you're boosted there is a good chance that it's chiped or you'd throw a CEL as soon as you built boost.</TD></TR></TABLE>
yeah i bet the ecu your running is chipped
pmpm06
Dec 28, 2007 07:29 PM
gsr9ek6
Oct 27, 2005 07:59 PM
