HELP.....B18a1 swap won't start!! Need to go to work!!!
Old Dec 29, 2007 | 06:37 AM
redhatch4u's Avatar
Default HELP.....B18a1 swap won't start!! Need to go to work!!!
Hi I have a 91 Hatch and a B18a1 swap. I hooked up everything. I checked my wiring, grounds, and everything that I "think" needed to start this baby up. Only thing that works is my lights and horn. When I turn the key I get no spark, fuel, and no click or anything from starter. The only click I get is from the ignition. I changed ecus and changed relay under hood and still nothing. I don't know what else to do. I am not a genius with hondas like some of you guys. I can do the basic stuff like swapping motors and wiring stuff. I have 2 days to get this things working cause I have to go to work. Someone please help me asap.
Thanks in advance.
Old Dec 29, 2007 | 07:24 AM
sirtef9's Avatar
Default Re: HELP.....B18a1 swap won't start!! Need to go to work!!! (redhatch4u)
thermo ground on?
Old Dec 29, 2007 | 07:44 AM
stillsmokey's Avatar
Default Re: HELP.....B18a1 swap won't start!! Need to go to work!!! (sirtef9)
Check all your grounds, the one under the battery, the one on the T-stat housing
Old Dec 29, 2007 | 08:33 AM
akandok's Avatar
Make sure the battery is not dead either..
But in theory at least your fuel pump should prime.. Even if the battery is almost dead...
Old Dec 29, 2007 | 04:06 PM
redhatch4u's Avatar
yup thermo ground on.
Old Dec 29, 2007 | 04:11 PM
redhatch4u's Avatar
Default Re: HELP.....B18a1 swap won't start!! Need to go to work!!! (stillsmokey)
I checked the grounds and all the wiring is good. I triple checked everything and still got nothing. I took my brothers harness off the car and still nothing. Then I tried my harness on his car and his car started right up. I am stuck. I again checked the relays and fuses and everything is good.
Old Dec 29, 2007 | 04:14 PM
redhatch4u's Avatar
But shouldn't the starter atleast click even when the battery is low??
Old Jan 2, 2008 | 12:38 PM
redhatch4u's Avatar
I am stuck...someone please help me....
Old Jan 2, 2008 | 12:45 PM
JimmyM86's Avatar
http://techauto.awardspace.com....html
Use this site and troubleshoot away!
Old Jan 2, 2008 | 06:41 PM
trustnoone7935's Avatar
Man it's silly but check your grounds just swapped LS in my hatch and wouldn't start i looked at everthing.Sanded my grounds on the body and the wires ends and she fired right up.
Old Jan 2, 2008 | 09:24 PM
redhatch4u's Avatar
Default Re: HELP.....B18a1 swap won't start!! Need to go to work!!! (trustnoone7935)
Here is an update....I changed all my fuses and my fuel pump is now working. I checked all my relays and they are good. I added more grounds to my engine and still the starter won't turn over. I don't even get a "tick" from the starter. I tested the starter by jumping it and it spin with no problem. I just don't know why it won't spin when I turn the ignition. :-(
Old Jan 8, 2008 | 06:12 PM
chrisyaj's Avatar
From: Saint Paul, Minnesota, United States of America
hey if thats the case its ur starter....
the solenoid in the starter is not good no more the wiring inside it.
if u can replace it. or just buy a brand new starter.
thats what i did
same problem
starter turns when u manually do it, but wont crank.
Old Jan 9, 2008 | 12:15 AM
424racer's Avatar
---YOUR CLUTCH PEDDEL SWITCH ---
ok ---
If the battery, starter, ignition, is good.
try-
there is a switch on your CLUTCH peddle if it is bad it wont let you start your car, (turn your starter over) nothing.
BUT if the switch is good check your clutch peddle arm there is a little plastic black cap that hits the switch. if its not there put somthing there so the switch can hit it or you can bypass the switch by pulling the clip off and runing a wire to each end...
or dose your car have any old or new alarms system?
check those fuse's.
good luck.
hcpbiker1@yahoo.com
EF'GSRrr91
Jan 22, 2015 05:29 PM
Cav3man
14
Mar 23, 2012 06:37 PM
.inbou
Dec 13, 2009 04:02 PM
tico
Aug 22, 2006 02:32 PM
wpgcivic
Dec 6, 2004 01:35 PM
