At what point does too much drop = Bad handling?
Hey all ive set up my konis/gcs and what I really want out of them is performance, not so much looks. My car is an em1, and Im planning to autocross it. Right now I have zero fender gap, but even with front extended tophats, my suspension travel is about 1/4 inch!
At what point does too much drop = bad handling characteristics?
As stated my car is currently 0 fender gap, but lacking suspension travel in the front. I may do fork mod to alleviate it though.
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">Spring rates? Current alignment specs? Photo of ride height?</TD></TR></TABLE>
what size rims/tires are you running?
It's a little long-winded, but Mike Kojima of SCC wrote these awesome tech articles about suspension. This goes to a big list of all teh articles. It'll tell you more about suspension than you'd probably ever care to know.
I can't believe you would ever need to do both extended upper mounts AND the fork trick in the front.
How did you determine that you only have 1/4" travel with extended top hats?
I had zero fender gap on my Integra w/ GC's and 380 lb/in front springs, and I never had any problems with bottoming out or with the stock upper control arms hitting the shock towers.
riceforlife
Dec 31, 2007 02:00 AM
Black R
11
Oct 24, 2005 11:52 AM
giff74
23
Dec 13, 2004 07:53 PM
