What kind of AFRs you running ?
Old Dec 28, 2007 | 08:45 PM
X2BOARD's Avatar
Default What kind of AFRs you running ?
I know there are posts about what AFR you should tune to... I know the answers that everyone gives... but I would like to know what all you DIY tuners are running in and out of VTEC ?
I currently have around 13.2-13.4 out of vtec and averaging 12.8-13.0 in vtec... dropping down to 12.6's from 7k - 8k.
What's your AFRs look like ?
Old Dec 28, 2007 | 09:12 PM
4piston's Avatar
Default Re: What kind of AFRs you running ? (X2BOARD)
I shoot for 14.5-15.0 for low load partial throttle driving and around 13.3 WOT for a naturally aspirated Honda on gas. Obviously you would be between those depending on the load.
Old Dec 28, 2007 | 09:31 PM
Hybrid96EK's Avatar
Default Re: What kind of AFRs you running ? (4piston)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4piston &raquo;</TD></TR><TR><TD CLASS="quote">I shoot for 14.5-15.0 for low load partial throttle driving and around 13.3 WOT for a naturally aspirated Honda on gas. Obviously you would be between those depending on the load.</TD></TR></TABLE>
same here..
Old Dec 28, 2007 | 11:07 PM
98vtec's Avatar
moderator emeritus
then make it leaner and richer and see which one the engine likes better.
Old Jan 6, 2008 | 02:03 PM
X2BOARD's Avatar
Forgot to ask what octane you're running on.
I am running on the low end 90-91 octane (sux for me)
Old Jan 6, 2008 | 02:24 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: (X2BOARD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by X2BOARD &raquo;</TD></TR><TR><TD CLASS="quote">Forgot to ask what octane you're running on.
I am running on the low end 90-91 octane (sux for me)</TD></TR></TABLE>
For the most part, the amount of octane you run, doesn't really affect the air/fuel ratios you tune for as long as it's pump gas and not race fuel, ethanol etc. The octane you run has more of a direct effect on the amount of timing you can tune your engine for.
Old Jan 6, 2008 | 02:41 PM
DonF's Avatar
Default Re: (00Red_SiR)
What guage and sensor are you using? They all read different, kinda like dyno's and compression guages.
Old Jan 6, 2008 | 04:02 PM
an2ny888's Avatar
Default Re: (DonF)
donf, so which wideband do you consider the most accurate? i have a plx and want to change it to an innovate
Old Jan 6, 2008 | 04:38 PM
98vtec's Avatar
moderator emeritus
Default Re: (an2ny888)
there is a wideband shootout somewhere on honda-tech
Old Jan 7, 2008 | 11:30 AM
DonF's Avatar
I have a PLX and AEM, I think Innovate was the most consistant in the comparision I saw. Still does not matter, if your engine runs the beast @13.7 on your guage, run it there. Different compressions and intake manifolds like different numbers, there is no one answer.
dohcgarage@714
Honda S2000
26
Nov 8, 2007 11:29 AM
todom
May 3, 2007 01:23 PM
B-JUSTINE
Honda Motorcycles
11
May 22, 2006 02:29 PM
99sibluehatchwitb16
11
Jan 20, 2006 10:32 PM
codyb13
Feb 21, 2005 02:50 PM
