Plug wires fall off at high rpms?
Old Dec 28, 2007 | 08:12 PM
recon23's Avatar
Default Plug wires fall off at high rpms?
every time I go into the high rpms, my plug wires slide off causing a loss of power? Anyway I can fix this?
Old Dec 28, 2007 | 08:42 PM
PrinceAli132's Avatar
Default Re: Plug wires fall off at high rpms? (recon23)
How old are your spark plug wires? How old is your distributor cap?
Your plug wires probably need to be replaced.
Ali
Old Dec 28, 2007 | 09:03 PM
recon23's Avatar
Default Re: Plug wires fall off at high rpms? (PrinceAli132)
I just replaced the wires in the past few months, and the cap looks new from when i baught it
Old Dec 28, 2007 | 09:17 PM
And they continuously keep falling/slidding off the dizzy cap?
Did you use OEM parts? A buddy of mine while on track at Sebring had his MSD plug wires fall off a few times. Ended up going back to OEM with no problems.
Ali
Old Dec 28, 2007 | 09:58 PM
NUISANCE's Avatar
If you want to keep the wires, zip tie them on. I switched to MSD and had the same problem until i zip tied them on.
Old Mar 6, 2008 | 06:25 AM
recon23's Avatar
Default Re: (NUISANCE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NUISANCE &raquo;</TD></TR><TR><TD CLASS="quote">If you want to keep the wires, zip tie them on. I switched to MSD and had the same problem until i zip tied them on.</TD></TR></TABLE>
will do, thanks man
ub3rn00ber
13
Oct 22, 2012 10:23 AM
mdixonjam
May 27, 2005 08:30 AM
korndog
Feb 28, 2005 08:44 PM
Reelizmpro
Oct 15, 2004 04:03 PM
bey
Oct 31, 2003 06:13 PM
