Suspension & Brakes Theory, alignment, spring rates....
ksports hurting my tender tush
Old Dec 28, 2007 | 03:16 PM
EG6B20Vtec's Avatar
Default ksports hurting my ***
way too bumpy I can feel even the slightest bump on the road is this because I preloaded the front too much I tightened the springs about 3 full circles and the back about 2
Old Dec 28, 2007 | 05:01 PM
Mr.OB*GYN_Rhett's Avatar
Default Re: ksports hurting my *** (EG6B20Vtec)
yeah, you bought ksports, they wont dampen well
Old Dec 28, 2007 | 05:35 PM
PIC Performance's Avatar
3 full circles from what? From when you thought they were already a little bit tight? A little bit loose? If pre-load is your problem, here's your fix:
1. raise the car, let the suspension drop to full droop.
2. Remove wheels
3. Loosen the spring perch and its lower collar until you can turn the spring by hand with practically no resistance, but it doesn't rattle up and down.
4. Put your wheels back on and drive.
Something tells me pre-load isn't your problem though.
Old Dec 28, 2007 | 07:01 PM
slammed_93_hatch's Avatar
Default Re: ksports hurting my *** (PIC Performance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PIC Performance &raquo;</TD></TR><TR><TD CLASS="quote">3 full circles from what? From when you thought they were already a little bit tight? A little bit loose? If pre-load is your problem, here's your fix:
2. Remove wheels
Something tells me pre-load isn't your problem though. </TD></TR></TABLE>
how does pre-load effect ride quality?
Old Dec 28, 2007 | 07:35 PM
Default Re: ksports hurting my *** (slammed_93_hatch)
It done too much, the springs will bind more easily. Nobody knows how much the OP pre-loaded the springs, but like I said, I don't think that's the problem.
Old Jan 3, 2008 | 03:31 PM
EG6B20Vtec's Avatar
3 circles from the spring is seated on the perch
Old Jan 3, 2008 | 03:32 PM
EG6B20Vtec's Avatar
then wat do u think is the problem
Old Jan 3, 2008 | 03:48 PM
bmoua's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6B20Vtec &raquo;</TD></TR><TR><TD CLASS="quote">then wat do u think is the problem</TD></TR></TABLE>
sell the K's and buy a coilover/spring shock combo. I'd suggest GC (ots spring rates) with kyb agx's or illuminas. If your looking for a better shock combo, koni's will do the job.
Old Jan 3, 2008 | 04:31 PM
lil'ek's Avatar
what's the spring rates on the k sports?
Old Jan 3, 2008 | 05:04 PM
bmoua's Avatar
Default Re: (lil'ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lil’ek &raquo;</TD></TR><TR><TD CLASS="quote">what's the spring rates on the k sports?</TD></TR></TABLE>
i'm guessing he's running the default 10k/6k.
Old Jan 4, 2008 | 05:32 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (bmoua)
which is extremely stiff for the street, at least for the front anyway. That's over 550 lb/in for those front springs.
And yes, pre-load has no effect on the ride when the full load of the car is on the springs, at least not only 3 turns-worth of the spring perch, which is probably 200 lbs. of pre-load (assuming about 8 threads per inch on the threaded shock body, and 550 lb/in springs, less than 200 if there is more than 8 threads per inch)
Do those Ksports come with spanner wrenches? Because you would need a spanner wrench to turn those spring seats once they're snug up under the spring.
Old Jan 4, 2008 | 09:24 AM
mike-y's Avatar
Default Re: (PatrickGSR94)
I bet 3 turns on the perch is hardly anything as far as preload is concerned.
I think the OP just didn't realize how stiff a 10k spring is.
Old Jan 4, 2008 | 09:47 AM
vtecvoodoo's Avatar
Future Texas Boy
Default Re: (mike-y)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike-y &raquo;</TD></TR><TR><TD CLASS="quote">I bet 3 turns on the perch is hardly anything as far as preload is concerned.
I think the OP just didn't realize how stiff a 10k spring is.</TD></TR></TABLE>
werd.
Old Jan 8, 2008 | 02:59 PM
EG6B20Vtec's Avatar
u mean the 2 wrenches that come with it
Old Jan 8, 2008 | 03:01 PM
EG6B20Vtec's Avatar
u might be right what can I do to get a more comfortable ride without removing them
Old Jan 8, 2008 | 11:04 PM
d1sturb3d's Avatar
Default Re: (EG6B20Vtec)
try turning the dampers to softest..if that does't work find or swap a lower spring rate for your coilovers..
Old Jan 9, 2008 | 03:49 AM
nater_1's Avatar
It is not preload... It is the fact that you purchased stiff springs for the street and did not know how stiff 550 is on the street. Swap for lighter springs, or get some progressive springs on a good shock (kyb/illumina/koni)...
Old Jan 9, 2008 | 08:00 PM
user 98292739's Avatar
its coilovers...
i dotn think the op realizes no matter what brand it is going to be stiffer then OEM. no matter what you buy its going to be stiff according to your standards.
mortificationrock
Suspension & Brakes
May 4, 2008 07:16 AM
InvaderTrax
May 8, 2007 09:51 PM
hondaracing1
Mar 28, 2005 09:32 AM
LB CRX
Nov 9, 2003 02:42 AM
cr00klyn718
May 13, 2003 09:38 AM
