frustration with clutch combo
Old Jun 28, 2002 | 02:45 PM
EF'n's Avatar
Default frustration with clutch combo
what clutch do i use with a jdm ys1 trans? i have tried 2k type r, 90 teg, and just now tried a 93 teg. none of them work.what the hell do i use?
Old Jun 28, 2002 | 02:51 PM
EF'n's Avatar
Default Re: frustration with clutch combo (revhardracing)
i have also tried a 2k crv flywheel and a 90 teg flywheel, although i think the b series flywheels are all the same for the most part. please someone save me
Old Jun 28, 2002 | 05:12 PM
CLICC916's Avatar
i have a 92-93 gsr clutchmasters stage one clutch...jdm b16a1 flywheel
Old Jun 28, 2002 | 05:36 PM
spettinger's Avatar
Default Re: frustration with clutch combo (CLICC916)
are the input bearings all the same on B series flywheels? as for the pressure plate, doesn't Exedy offer one for a cable B16 trans?
Old Jun 28, 2002 | 05:54 PM
EF'n's Avatar
so i take it you have the ys1 too? i did some measuring and it looks like the arm goes like half way up before the t/o bearing hits the pp then it looks like it will work with the rest of the throw. i thought that the arm was going to be all the way down and not lift up much before contact with the pp.
Mindgamez
Transmission & Drivetrain
Oct 2, 2009 07:40 AM
bigger junk
Mar 15, 2005 05:54 AM
90Integra
Nov 28, 2004 07:07 PM
DA-B16
Mar 28, 2004 11:55 PM
rice4life
May 9, 2002 09:04 AM
