Who has experience with Endyn's smaller chambers?
Old Dec 28, 2007 | 10:28 AM
psegs80's Avatar
Default Who has experience with Endyn's smaller chambers?
I'm planning on entering the Touring Class in the CCTC (Castrol Canadian Touring Car Championship) and I have to keep OEM pistons.
I have A JDM B18C (type R) and when speaking with Larry form Endyn, he suggested CNC chambers that he can get down to 39cc which would yield 12:1 compression.
Who has had something like this done???
Will run with eighter Endyn's cams or my current SK2 Pro 1+, Endyn custom Intake manifold and a Rage small tube header!
Cheers
Old Dec 28, 2007 | 10:40 AM
Natural Aspirations's Avatar
Default Re: Who has experience with Endyn's smaller chambers? (psegs80)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by psegs80 &raquo;</TD></TR><TR><TD CLASS="quote">
Will run with eighter Endyn's cams why or my current SK2 Pro 1+, Endyn custom Intake manifold why and a Rage small tube header why !
Cheers</TD></TR></TABLE>
I run a 38cc chamber through milling alone I like it...
On the parts selection
Old Dec 28, 2007 | 11:18 AM
psegs80's Avatar
Default Re: Who has experience with Endyn's smaller chambers? (Natural Aspirations)
Why = Stronger mid range. I have a 4.40FD trany with ATS close ratio gears so I don'thaveto rev it to 9000 to fall back in the power ban. I would like to shift it arround 8500 for longterm reliability and I need the strong mid range for coming out of the corners as well!!
I'm open to suggestions!!!!
Cheers
Old Dec 28, 2007 | 11:30 AM
then why use a high rpm cam and manifold? Then use a B16 header?
Old Dec 28, 2007 | 11:39 AM
psegs80's Avatar
Default Re: (Natural Aspirations)
The intake manifold will be custom made By Larry to helpt 6000-7500rpm range. As for the cams, I know my current PRO1+ have a a un-usable power ban..to high. As for the Rage Small tube header, I noticed a big torque gain on my current setup over my old Spoon one piece header!
I have a set of Toda Spec B camshafts that I like but, I have been told that they are bad on valvetrain stability??
Cheers
Old Dec 28, 2007 | 11:43 AM
Default Re: (psegs80)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by psegs80 &raquo;</TD></TR><TR><TD CLASS="quote">The intake manifold will be custom made By Larry to helpt 6000-7500rpm range. As for the cams, I know my current PRO1+ have a a un-usable power ban..to high. As for the Rage Small tube header, I noticed a big torque gain on my current setup over my old Spoon one piece header!
You have got to be one of the first ones I have hear claim Pro1's had an unusable powerband.....
Old Dec 28, 2007 | 11:52 AM
psegs80's Avatar
When I removed My spec Bs to replace them with the PR0 1+, I had to remove fuel all the way up to 7500rpm, the I was at par untill 8400rpm and them I had to ad more fuel till 9200. I played arround with the cam gears and 8650rpm is the lowest I could get the peak power without loosing to much peak whps...Vtec was at 6400 rpm and the power-ban really just strated at 7500 so weak when coming out of corners!!
I only had 11.3:1 Comp and no port work so I could of been over camed
Cheers
Old Jan 2, 2008 | 09:40 AM
P12 EG6's Avatar
dont talk bad about the custom intake manifold .. thats what i got Larry did my head and matched the intake manifold to maximize mid and upper mid powerrange. paired with his cams and a good exhausat with stock pistons mines a beast!!! if larry says itll be good trust him it will!
Old Jan 2, 2008 | 12:23 PM
psegs80's Avatar
Default Re: (P12 EG6)
Is yours a Type R as well. If you have your dyno please send it to me pat@bullyclutch.com...if you don't, could you let me know where your peak Torque and HP was!!
Thanks
Modified by psegs80 at 2:21 PM 1/2/2008
Old Jan 2, 2008 | 12:34 PM
Combustion Contraption's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by psegs80 &raquo;</TD></TR><TR><TD CLASS="quote">if not where di peak Troque and HP come in!!
Thanks</TD></TR></TABLE>
Is this a question or a statement?
Old Jan 2, 2008 | 12:42 PM
mar778c's Avatar
Community Builder
Community Influencer
Just stay stock, you'll have fewer problems.
Old Jan 2, 2008 | 01:09 PM
Rickdrizzle's Avatar
Default Re: (Combustion Contraption)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Combustion Contraption &raquo;</TD></TR><TR><TD CLASS="quote">
Is this a question or a statement?</TD></TR></TABLE>
lol
Old Jan 2, 2008 | 01:23 PM
psegs80's Avatar
Default Re: (Rickdrizzle)
Yep I desirved that lol
Stock power will put me in the back of the field regardless on driver skills or Chassis setup but I agree on the fewer problems!
Cheers
hondateg10
Aug 5, 2008 05:03 AM
.CUBISH.
27
Jan 14, 2008 09:50 AM
dbiker207
27
Apr 6, 2007 12:49 PM
-Championship-
Sep 6, 2006 02:41 PM
1994GSR
Dec 22, 2004 09:59 AM
