Suspension & Brakes Theory, alignment, spring rates....
will this damage a shock?
Old Dec 27, 2007 | 11:41 PM
the soL that could's Avatar
Default will this damage a shock?
Can you damage a shock by spinning the shock piston? Thanks...
Old Dec 27, 2007 | 11:48 PM
01-0041's Avatar
Default Re: will this damage a shock? (the soL that could)
Yes, but it will take some time so just watch how much you do it.
Old Dec 27, 2007 | 11:53 PM
Default Re: will this damage a shock? (01-0041)
are we talking extreme... ?
for example, if i turn it 5 full rotations, will i have completely destroyed my shock?
Old Dec 28, 2007 | 02:55 AM
riceforlife's Avatar
Uh what? Im pretty sure if you spin the piston its ok.... THe thing you dont want to do with say.. konis is overturn the adjuster **** at the top.
But somebody should clarify that
Old Dec 28, 2007 | 10:12 AM
CRX Lee's Avatar
What did you spin it with? Five really fast rotations with an air tool can be enough to untorque a piston and cause failure. Five turns by hand or maybe at ratchet rotation speed should be no issue at all. More info needed. A shock with a solid rod (non externally adjustable) with be less likely to damage than an externally adjusted shock with a hollow rod.
My response would be to tighten it on up and use it and see if you notice any handling or adjustment issues. Your alternative is to have it dyno tested to know for sure but unless you wailed on it with an impact tool, you are probably fine. PM me if you have any specific questions.
firebane
Suspension & Brakes
Apr 16, 2007 10:40 AM
EngineNoO9
Suspension & Brakes
Jul 22, 2005 04:32 AM
Fez
Oct 22, 2002 02:28 PM
grngsr01
Sep 29, 2002 03:03 PM
erniecars
Jul 16, 2002 12:08 PM
