Rear Disc brake ???
i got some rear disc brakes from a 92 Integra DA Gsr and i was wondering if they would work on my 96 ek. i'm sure the e-brakes won't work and i'll need a prop valve but will everything else line up? thx a lot in advance.
From: Dont You Just Love Lynn Cops, Boston MA, USMA
As long you change the LCA's you be ok.
Some 96 ek did not changed there prop valve, some had to.
For the e-brake cable, you have to use the 99 si cables i believe?
Cool Cool Island Breezes. BOY-EE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phyzJunkieCivic »</TD></TR><TR><TD CLASS="quote">As long you change the LCA's you be ok.
You dont have to change the LCA from your originals. You can use your original LCAs. But yes, you do need 99-00 Si ebrake cables
yea, lca would be fine...i'm sure i can just use them from my stock ek brakes. yea, prop valve needs to be changed to 40/40 if it's not Si. and brake booster /MC need to be changed if it's not the EX model
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phyzJunkieCivic »</TD></TR><TR><TD CLASS="quote">You cant use 92 DA lca's
They are diffrent than the EKs
Or... can you? Will that throw it off?</TD></TR></TABLE>
He never said anything bout LCAs. He has the rear trailing arms from a DA. You can use the rear trailing arms from any model double wishbone civic/integra to any model of double wishbone civic/integra. The LCA has nothing to do with it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B serious »</TD></TR><TR><TD CLASS="quote">
He never said anything bout LCAs. He has the rear trailing arms from a DA. You can use the rear trailing arms from any model double wishbone civic/integra to any model of double wishbone civic/integra. The LCA has nothing to do with it.</TD></TR></TABLE>]
Oh my bad, i thought he was planing on useing the DA lca.
I know you can use any trailing arms. Thanks for correcting my drunkness
'96-EJ6Hatch
32
Mar 18, 2012 05:21 PM
primojoe20
Oct 22, 2007 02:20 AM
