CEL
Old Dec 27, 2007 | 06:49 PM
Shaynepolevault's Avatar
Default CEL
My check engine light came on and I used the trick from the forum with the wire and I think I through a 41, but im not sure!what classifies it as a long blink? I either through a 41, or a 5. a 41 is the primary oxgen sensor does anybody know where this is located? a 5 is manifold absolute pressure sensor. The blinks were 4 normal blinks about 1 second or 2 lit solid, and the 5th blink was really quick flash so i think i through a 41, so if anybody knows where number 41 is that would be great and also if i did this correctly. I also just put on a AEM cold air intake about 1 month ago, so can this have anything to do with it?
Old Dec 27, 2007 | 06:56 PM
z6hatchboy's Avatar
Default Re: CEL (Shaynepolevault)
Well the primary is the first o2, its on the exhaust manifold. And the map is on top of the throttle body.
Old Dec 27, 2007 | 07:06 PM
Default Re: CEL (z6hatchboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6hatchboy &raquo;</TD></TR><TR><TD CLASS="quote">Well the primary is the first o2, its on the exhaust manifold. And the map is on top of the throttle body.</TD></TR></TABLE>
Do you know where all the oxygen sensors are located on a 95 coupe dx?
Old Dec 27, 2007 | 07:08 PM
Also they called it a Primary oxygen sensor heater. Is this still the one located on the exahust right before the cat?
Old Dec 27, 2007 | 07:20 PM
bump
Old Dec 28, 2007 | 12:20 AM
bump bump! help please!!
Old Dec 28, 2007 | 06:31 AM
Probot's Avatar
primary O2 sensory is on the exhaust manifold and the secondary O2 sensor should be located on or near the CAT. thats where it is on my 00 EX..il search it real quick and let you know
PS...search button is your friend
yea, regardless of year..your primary O2 sensor is on the exhaust manifold
https://honda-tech.com/zerothread?id=1955553
drew_kousk
Jan 31, 2010 05:31 AM
00fbp
15
May 6, 2008 07:02 AM
boostedh22lude1
Mar 28, 2008 08:04 AM
numbtoes
Aug 11, 2006 09:35 PM
jdmrealm
Jan 31, 2002 12:33 AM
