Problems with clutch?
I just replaced my clutch, slave,master cylinder. When starting to drive the clutch feels fine. After driving for like 15-20 min the clutch starts slipping. What could the problem be. If i cant fix this i will sell my car. This is very frustrating. It's a 94 ex accord 5 speed.
Yeah i break the clutch in. Never rode it hard. The clutch is a oem clutch that i bought at napa. The clutch will slip only when the car has been driving for awhile. This seems weird. Could be the clutch getting hot while driving for awhile.
not likely, unless somehow you are getting coolant on the surface of the clutch, which is nearly impossible if the leak is in the radiator. You mentioned you changed the clutch and all the related components, did you properly bleed the clutch? are all of the fluid lines hooked up all of the way, or possibly leaking?
I check all the fluid lines and everything is fine. How do you bleed the clutch?. Also sometimes the clutch pedal would feel rough at times. It usually feels soft but now once and awhile the clutch pedal feels alil hard to engage.
B18Redline
Nov 13, 2007 11:09 AM
