P72 ECU IN 96 D16Y8?
Old Dec 27, 2007 | 01:25 PM
Civic 96 Sedan's Avatar
Default P72 ECU IN 96 D16Y8?
A friend of mine told me its possible to take a 96 integra GSR ECU (p72) and put it in a 96 civc d16y8. He said the Vtech would kick in longer and stronger. Im still skeptical so thats why I came here. I was just gonna run with the p2p ecu until I the story about the p72.
Old Dec 27, 2007 | 01:29 PM
crazyguy's Avatar
Default Re: P72 ECU IN 96 D16Y8? (Civic 96 Sedan)
nope.thats bullshit. it wont work. p2p is your best shot
Old Dec 27, 2007 | 01:42 PM
Chaveli's Avatar
From: Arlington/ South central LA, Texas/ Cali, USA
Default Re: P72 ECU IN 96 D16Y8? (crazyguy)
I know this may be O so noob, lol but what is p2p ?
Old Dec 27, 2007 | 01:56 PM
F40's Avatar
F40
Default Re: P72 ECU IN 96 D16Y8? (Chaveli)
The stock EX(D16Y8) ECU.
Old Dec 27, 2007 | 02:09 PM
b16b_eg3's Avatar
No offense, but your friend is an idiot. What makes vtec kick hard is camshafts and proper fuel managment (via ecu). Why would anyone use a p73 (DOHC ecu) on a SOCH anyways? That's just asking for trouble. Stick with the p2p or go obd1 and have it chipped & tunned. You won't regret it (even for a future DOHC swap).
Old Dec 27, 2007 | 02:14 PM
Wannabe JDM's Avatar
if the p72 managed to run the single cam (which i highly doubt) then its gonna run like ****. vtec "kick" has nothing to do with your ecu. it has to do with the cam profiles. if you look at a vtec cam shaft youll notice 2 outside primary lobes and a bigger inside secondary lobe. that inside secondary is the vtec lobe. so when your ecu reads the proper rpm (and other proper factors) the vtec solenoid opens up and locks the valves on the cam profile of the secondary lobes. thus giving you the "vtak just kicked y0!!!" feel.
Old Dec 27, 2007 | 02:16 PM
97Ej6mike's Avatar
only situation where an integra ECU will run a SOHC hard is with a d16y7 block, OBD1 parts (z6 manifold for example), and an obd1 p75 ( all in a obd1 car). GSR ecu on an OBD2 motor will make it run like ****. Plus GSR reads for IAB's, and you'll get a CEL for that.
Old Apr 29, 2019 | 11:16 PM
Kare Choun's Avatar
You guys are all wrong it would work fine also a plus you can rev to 8000 or 8500 and vtec comes in at 5000 using the obd2a gsr
Old Apr 29, 2019 | 11:44 PM
tony_2018's Avatar
Fish Twig
ohstfu...
Old Apr 30, 2019 | 08:59 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Soooo, your first post is a 12 year-old "Dead Thread" bump... and the information that you have provided is completely and utterly flat wrong !!! This makes you either a "Troll" or mechanically ignorant... neither are useful here in this forum. If you are the former, please go away... and if you are the latter, might I suggest you focus on asking questions for a while and refrain from answering any during this same period.
Welcome to the board.
wastedyouth2542
Dec 6, 2010 07:47 AM
pinoyboy204
Jul 12, 2006 03:20 PM
All Day
Mar 8, 2006 06:10 AM
fastfour
Apr 11, 2005 09:04 PM
98lude
Jul 28, 2001 07:48 AM
