How To Fix Dashboard Light
Old Dec 27, 2007 | 11:24 AM
buzlink's Avatar
Default How To Fix Dashboard Light
It appears that the bulb for my dashboard has gone out. The one the illuminates the speedometer and such.
Is there a fuse for this area that I should check first or any other things?
How does one replace the bulb for the dash?
Thanks
Old Dec 27, 2007 | 11:30 AM
z6hatchboy's Avatar
there is a fuse for that, but i think it control a few more lights than just the dash. Check it anyways though, replacing the bulbs arent hard just pull the cluster take the back off, ill post the thread link if i can find it.
Old Dec 27, 2007 | 11:35 AM
andoxviii's Avatar
Go to the FAQ section.
Under "Interior Removal" and "Interior Alterations" there are many threads that will help you.
The author of the FAQ thread went through a lot of trouble to save everybody else that same trouble. Don't make his efforts a waste. USE THE FAQ THREAD.
Old Dec 27, 2007 | 11:36 AM
z6hatchboy's Avatar
https://honda-tech.com/zerothread/661308 , this will show you how to pull it out. ^ he has a point too
Old Dec 27, 2007 | 11:43 AM
buzlink's Avatar
Default Re: How To Fix Dashboard Light (buzlink)
Thanks for the link,
If all of my dash is out, could it sill be the bulbs since there are so many of then in the console?
Old Dec 27, 2007 | 11:46 AM
z6hatchboy's Avatar
If all the dash is out its probably the fuse, i think its somewhat rare for them all to go at once.
Old Dec 27, 2007 | 12:02 PM
phyzJunkieCivic's Avatar
From: Dont You Just Love Lynn Cops, Boston MA, USMA
I had a local shop installed my alarm system.
They manage to fry all my bulbs in my cluster.
How they do it i dont know? expletive up thing they did was put diffrent color bulbs back.
Old Dec 27, 2007 | 12:37 PM
Eran's Avatar
HT White Ops
If all your lights are out, it's a fuse or your dimmer switch.
Old Dec 27, 2007 | 02:43 PM
adamrg85's Avatar
most likely its your dimmer switch, honda dimmer switches always go bad, I seen it happen to many times. this is what you do first, check your fuses and if that isnt the problem before you pull your cluster out. pull your dimmer switch out becauese all your your dimmer is a manual on/off switch, i think that its three wires behind the dimmer, all you have the do is splice the two wires that send the power to the lights on your dash together, but i cant remember which two wires to splice together. so just try different ways untill your dash lights come on. if this solves your problem then you have two choices 1)get another dimmer switch, or 2)leave the two wires behind the dimmer splice together and be glad you can see how fast you are going at night, (thats why i did and 4 of my friends). Let us know how it turns out.
crxaddikt
Oct 15, 2011 11:36 PM
Mr. Prelude
May 12, 2011 03:16 PM
got00rice
Dec 5, 2009 01:21 PM
alfonsoleo
Dec 14, 2008 09:55 PM
ImXposed
Jan 16, 2006 08:32 PM
